glitch web site
Discussion in 'PC Gaming & Rigs' started by UncagedTyphoon, Jul 1, 2003.
  1. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - M02-Farm
    The side opposite of the farm and the houses. Go to the rockson the right when facing the barn. I dont know how but this kid was walking outside of the level on the street. He actually got a kill on an unsespetcing sniper but he couldnt get back in the level so he quite.
    Glitches for - M03-RR
    Where that blown up house is near the train, you will see what resembles a fire place in the blown up house. You can actually crawl into the fire place and stand up.
    Glitches for - M04-Village
    Looking away from the bridge facing the crossroads. The first house on the left. The bottom right corner of the house. If you crawl into it u can see through it and see most of the northwest section of the map
  3. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - M05-Embasy
    There are 3 entrances to the Embassy courtyard. On the side near the busses, go straight into the courtyard. Immediately turn right and stand facing the gate on the left. Walk as far into it as possible. Then turn around and walk backwards into it as far as possible. Then quickly turn around and lay flat. You should be able to see and shoot through the wall where the street with the busses are.
    Go to the steps by the broken road adn follow the wall behind the hotel. just after the top of the steps you will see a point were the texture changes and theres a shimmering thin line inbetween, if you lay down you can crawl into this line and see right through the hotel (it also works if you glitch peak into the wall at the right place). You only have a small fire arc but you can see right down to the ally by the buss and actually in the ally to the north of the bus.
    Once inside the Embassy compound head to the front entrance, lay down in the gap between the left gate and the wall then peek to your left. You can now see through the wall.
    Go into the hotel. Right by the window there is a plant. Lay down and squeeze yourself between the plant and the wall. If you are in the right spot, you will be able to lean right and see the the wall to the other hallway in the hotel.
    In the back alleys by the hotel, it forks off. do not go down the stairs. It is by one of the respawn points, and there are 2 dumpsters that you can go behind. Walk srait to the back, lay down as far as you can, and peek right. If you do it right you can see through the alley, to the part where you go down the stairs.
    If you enter the embasy yards and go to the front gate now lie down behind the left hand side of the fence the use the direction pad press left part of the embassy wall disapears giving you a wider angle towards the parking.
    Glitches for - M06-Castle
    The house that is the furthest south west from the castle where 1 of the seige bases usually is. On the front porch there is a cylinder to the right of the door. If you lay down just to the left of the cylinder facing the house, there is a triangle on the wall. If you move up & down while crawling forward, you can crawl into the house & stand up. You can then shoot 360 degrees without being seen or shot. Major glitch for defending that base
  4. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - M08-Battlefield
    WHELL THERE IS THE OLD CLIME IN THE BACK OF THE HELOCOPER GLIYCH. YA THAT RIGHT YOU CAN CLIME IN THE BACK OF A HELOCOPER JUST LAY DOWN AT THE END OF THE HELOCOPTER AND CRAW INTO IT AND YOU CAN SEE RIGHT THROUGHT IT GUOTE BAD GRAMMER
    Glitches for - M10-Vilnius
    You need to go to the middle of the map. Here you will find the blown up buildings. There is a spot below the second floor near the rubble piles. You will find what appears to be a step of some sort with a low lying wall gaurding your position. If you lay down and crawl into the corner you will get stuck but you can see the entire courtyard on the building side of the wall that surrounds the compound.
    Glitches for - M11-POW
    In the NW end of the map where the extraction zone would be in mission mode. Their is a hole in the fence that allows you to access the black portion of the map. This is more of a cheat then a glitch. Added it anyway.
    All you do is get into the North Eastern segment of the camp. Next, get next to one of the barracks and lay down. All the barracks here are elevated on blocks, so you are able to crawl underneith them. Unfortunately, once underneith, you have the ability get up and kneel or stand. Once your view is inside the building itself, you are seeing through the backside of all the polygons in that building, allowing you to see a small majority of the segment.
    YOU CAN CRAWL UNDER THE BILDEINGS ANG STAND UP QUOTE CANE BE KILLED BY THE BACK
  5. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - M12-Docks
    If you go down the first ramp on the level(the one tht leads down to the 2 entrances) you will see a black door. If yoy lay down and lean right you are able to see through it and up onto the fence area and much more. If your siege base is on the left side of the map the person using this glitch can see practically the whole base so it is a very deadly glitch.
    what you do is crawl under the tanks and go to where half way there is a black ring and have that right above you then stand up and you can walk with your upper body in the tank.
    if you go to the northwest on the map go into the pit that is there and go to the rock in the corner and get your banocks out and zoom in all the way and crawl into the middle of the rock and then you can go though the crates that are behind there
    Glitches for - M13-Airbase
    if you go to the plane go to the tail and crawl under it and when the tail meets the plane stand up and go forward and it will be see through
    Glitches for - M14-Mountain
    The top top left part of the map, u can go through the fence and lie down off the actual map.
    Head towards the south east slope that goes down towards to camp with the tents. If you stick right up against the cliff wall and crawl down this path/road you will eventually lose your head into the cliff about half way down. You can now see all off to the right where people would sometimes hide, as well as the back of the tents without having to go up onto the sniper ledge with the little wooden hut.
    Glitches for - M15-Red
    THERE IS A DITCH GLITCH IN THIS LEVLE. YOU CAN SEE WERE THERE IS A HOLE IN THE GROUND JUST MAKE SURE YOUR GUN IS STRATE UP:GUOTE CAN GET KILLED FROM THE BACK.
    Glitches for - MP01-Small
    in the back corner by the house if you go to the ledge look towards the rock while standing and then lay down you could see through th whole map
  6. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    This one is kinda weird. It involves 2 people and is rather difficult to explain. First, cross the river in the center to the side opposite the house. If you turn right, I believe the 2nd rock is sort of close to the river. The person that will be going into the river (that is what happens,) needs to turn around, crouch, back as far as possible in between the rock and the river. Next, turn to the left so you are looking directly at the river. Now lay down and dont move. The second person must now do the same thing you did by turning around, crouching, backing up (and must keep backing.) Once the 2nd person is doing that, the person laying down needs to push forward on the left joystick and hump fairly quickly. After about 3-5 seconds, you should fall into the river (if done correctly.) This glitch is made useless because it takes so long to do and is so out in the open, but its still fun. If you turn left, you can go inside the first rock, climb on top of the second mound, and go inside the waterfall and the rocks onto which the water falls.
    Glitches for - MP02-Night
    There is a crashed helicopter in the Night Battle level. Go to the tail of the helicopter, lay flat, and crawl into the back. You can not be seen from the inside of the back of the helicopter. You can shoot outside it too. Even when people launch grenades at the helicopter, it can not hurt you. You can stand up too in the back of the helicopter.
    Glitches for - MP05-Day
    If u respawn next to the office go to the crates in the midlle ally way out by the road u will c a crate (not the one that has two, jut the one)walk in to the group of crates have your back facing the stack of crates(2) and that lonly crate lay down and get your binocks out and slide in side of it then once in side of it u can get on your knees and go to your gun and kill , this also woks at the crates in front of the wearhouse put the crates that have 2 u can not get on your knees only your belly
    if you go to the north west of the map go into the pit that is there and go to the rock in the corner and get you banocks out and zoom in all the wayand crawl into the middle of the rock and now you can go though the crates
    sorry i meant northeast on the socond glitch
  7. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - MP06-Day
    Outside the wall in the North East against the tower on its west side there is a pile of dust. You will notice that this dust meets the edge of the tower, just where it enters the wall. When you lay down, facing in, toward the wall, and crawl close enough at the correct angle, you can lean left and see through the wall, both into the castle area, but much more on the other side of the tower, outside the castle walls. You can see from the North end of the map all the way to about five meters away from the Eastern of the two Southmost towers.
    If you go to the house that is central and north there is a pile of wood if you lay down near the pile of wood and crawl forward into the corner of the building you will go through the wall. Then when in the house the walls are see through and you can shoot through them. However the enemy cannot see you. This is a brutal glitch it is impossible to kill the guy in the house unless you get the door open.
    In the South East tower, toward the bottom, where the ramp begins up the tower, it turns sharply about a meter after it leaves the ground, so that the rest of the ramp follows the edge of the tower up. Where this turn is, if you lay down just right in this corner, you can lean right and see through the wall that leads West, including the inside of that tower, right up to the top doorway to the wall.
    Inside the white house in the North West corner of the inside of the castle, if you go inside, to the North West room, where there is a bed, you can crawl into the bed. You can get into the South West corner of the room, between the bed and the wall, facing the bed. Then if you lay down and crawl forward, you go into the bed. While lying down inside the bed, you cannot be seen anywhere outside the bed, and unless you allow someone to crawl in from the same end you did, no body will ever get to see you. I have not tested it, but I believe I have heard of this previously, and whoever mentioned this glitch then stated that you can not even grenade the person inside the bed, because it will not do anything to them.
    In the house with the 3 windows you can look out of, if you are looking out those 3 windows directly behind you there is a dresser, if you crawl under the dresser/desk you can see through one side i think this will give you an advantage because who ever walks in will get shot because noone ever pays attention to that kinda stuff.
    On top of the wall, just ouside the South side of the North East tower, against the outside of the wall, if you lay down parrallel to the wall, looking into the little bit of the tower that comes away from the wall and lean right, you can see half of the ramp leading up inside that tower, as well as the area on the outside of the East wall. Because
  8. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Glitches for - Training
    When you go to the command post in training, there are all those blocks in the middle. Go to the back of the block farthest from the upstairs part, face it, and lay down. You can see right through it. Depending on where you lay, you will see through it, or it will semm likme you are on top of it, but your really not.
    If you go upstairs on the balcony and move all the way over the top of the door that is downstairs(below you), lay down and crawl off the edge as far as you can. Once you are out as far as you can you will be hanging over the edge(under the railing)and directly over the door. At this point stand up and you will fall off the balcony and get injured. If you did it right and landed right on the door you will see that this glitch can span almost the entire map(not that the map is that big). I will leave this glitch at that and let you experiment to see what people can do with this glitch. *hint Walk around in the dark hallway and up the stairs a bit.
    In the middle area, on the bottom, where the two large cement blocks are, go to the wall opposite the upper level. Go up to the block, while being between the block and the wall, and lay down facing into the block. No matter where on the block you do this, your view automatically jumps up to as though your head was sitting on the upper surface of the block. Now, you can see the upper level, the door under it, and most of the inner area, without being seen more than half of your body, at the bottom of the block, in back.
    POW Camp - 01
    Almost everyone knows this glitch now, but it deserves it's place among the ranks here. All you do is get into the North Eastern segment of the camp. Next, get next to one of the barracks and lay down. All the barracks here are elevated on blocks, so you are able to crawl underneith them. Unfortunately, once underneith, you have the ability get up and kneel or stand. Once your view is inside the building itself, you are seeing through the backside of all the polygons in that building, allowing you to see a small majority of the segment.
    MP06 Castle - 01
    Outside the wall, in the North East, against the tower, on it's west side, there is a pile of dust. You will notice that this dust meets the edge of the tower, just where it enters the wall. When you lay down, facing in, toward the wall, and crawl close enough at the correct angle, you can lean left and see through the wall, both into the castle area, but much more on the other side of the tower, outside the castle walls. You can see from the North end of the map all the way to about five meters away from the Eastern of the two Southmost towers.
  9. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Embasy - 01
    You only have a small fire arc but you can see right down to the ally by the buss' and actually in the ally to the north of the bus.
    Its pretty obvious if someones doing it as they are half in a wall
    Embasy - 01
    Training - 01
    I've looked closer at this glitch, and not only does your body stay on the ground, halfway inside the block, but since your body is what must get hit for you to be damaged, it doesn't even matter if you are getting shot where you can see from.
    M03 Rail Road - 01
    Where that blown up house is near the train, you'll see what resembles a fire place in the blown up house. You can actually crawl into the fire place and stand up.
    MPCastle or Day Castle Glitch - 02
    M11 POW Camp - 02
    In the far North West corner of the map, along the North fence, several meters away from the far West edge, there is a large hole cut in the chainlink fence. It looks as though someone has cut this hole as someone would in reality. Maybe a disgruntled employee? Who knows, but we don't support his ways, for this glitch is one of the worst there could possibly be. If you lay down, you can easily crawl through the fence, allowing you to see and shoot through the backside of it, as well as the background forrest that happens to be a solid texture. If your seige base is outside the camp anywhere, you are SOL, and I don't mean hot either. If your seige base is inside the base and they have A) Grenades, B) A rocket launcher, C) A sniper rifle, or D) Binoculars, then you are also SOL.
    MP06 Castle - 03
  10. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    MP06 Castle - 04
    Inside the white house in the North West corner of the inside of the castle, if you go inside, to the North West room, where there is a bed, you can crawl into the bed. You can get into the South West corner of the room, between the bed and the wall, facing the bed. Then if you lay down and crawl forward, you go into the bed. While lying down inside the bed, you cannot be seen anywhere outside the bed, and unless you allow someone to crawl in from the same end you did, no body will ever get to see you. I have not tested it, but I believe I have heard of this previously, and whoever mentioned this glitch then stated that you can't even grenade the person inside the bed, because it won't to anything to them.
    MP06 Castle - 05
    MP02 Night Battle 01
    Helicopter - Locate the helicopter on night battle, position yourself at the very back, below the tail. Crawl towards the front of the helicopter. You will soon start to crawl INTO the vehicle. Once completely inside, you can crouch/stand and have full 360 vision. You can shoot out, but NOTHING can kill you. Rockets/Grenades etc.
    IT SUCKS!!
    Night Docks-01
    Night Castle - 01
    Embassy 02
  11. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Villiage 01
    Village 01
    I've seen this glitch, and if you crawl as far forward as you can, you will be able to stand up and walk around, similar to the house inside the Day Castle, or the other house outside the castle in the Night Castle.
    Training 02
    THE MOUNTAIN 01
    The top top left part of the map, u can go through the fence and lie down off the actual 'map'
    Day Castle
    I've noticed that on Day castle, if you walk very slowly at an extreme angle into the House with the bed glitch, you can merge into it(you can feel yourself sink into the map once you reach the gap between the stairs and the house). While this is harder to do than the woodpile glitch, I just thought I'd let it be known since it can be done relatively quickly if done correctly.
    mp01 river
    Embassy
    When you go through the garage toward the embassy, you can lay down on the left side peaking your head out. You can shoot people, they can only shoot you from behind
    Embassy:
  12. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Embassy (Forgot wat #}
    Night Docks
    i got one i think you dont have that is in NIGHT DOCKS to go int the tanks. what you do is crawl under the tanks and goto where half way there is a black ring and have that right above you then stand up and you can walk with your upper body in the tank.
    Vilnius
    I discovered this one today by accident but I think it is similiar to the corner glitches we have seen posted many times. You need to go to the middle of the map. Here you will find the blown up buildings. There is a spot below the second floor near the rubble piles. You will find what appears to be a step of some sort with a low lying wall gaurding your position. If you lay down and crawl into the corner you will get stuck but you can see the entire courtyard on the building side of the wall that surrounds the compound. This could have been a great position since alot of players tend to run through the middle of the map to get to the main street.
    stronghold and creekbed
    not the kinda glitch you should wourry about, just a small, annoying thing. if youre crouched down and you put ur back to the wooden fence you go a little bit behind it, and when ur trying to move with your back to the fence and look around, it gets a little bit annoyin
    another one at the embassy is if you enter the embasy yards and go to the front gate now lye down behind the left hand side of the fence the use the direction pad press left part of the embassy wall disapears giving you a wider angle towards the parking.
    you can only be killed from behind
    enjoy later guys
    In M04
    by a rock next to a hill, u can walk backwards, laydown and be able to see through the rock and shoot someone up by the street.
    embassy
    go behind the south dumpster in the alllys on embassy
    and go up to the wall and peek towards it
    MP06 Castle 04
    On top of the wall, just ouside the South side of the North East tower, against the outside of the wall, if you lay down parrallel to the wall, looking into the little bit of the tower that comes away from the wall and lean right, you can see half of the ramp leading up inside that tower, as well as the area on the outside of the East wall. Because of the way you are leaning when you do this, you cannot aim to the right of the tree just east of the tower, but you can see a bit past it. You can shoot between the tree and the wall of the tower that is blocking your view to the left.
  13. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Training 01
    MP06 Castle 02
    Inside the walls of the castle, at the brown house in the South East, get next to the Eastmost side, where the boots are on the steps. Be next to the steps on the side where the boots are. Lay down in the corner where the steps meet the house. You want to crawl up the side to where it looks to you like your head is between the boots and the wall (preferably so close, you may only see a tiny portion of the toe of the far boot running across the bottom of your screen, but hopefully none of the boot on the right side of the screen). You may need to play around with this one a bit, but it's easy to do, when you get in place. Next, simply lean left. You should see through the house to most of the interior of the castle.
    For u glitch users and did not think that there was none on day docks
    well there r several there u just got to be fast on getting there and getiing in the doodoo ok to do this glitch u cant have your gun in hand to do it u need your benocks here is how u do it k its shocking ............... If u respawn next to the office go to the crates in the midlle ally way out by the road u will c a crate (not the one that has two, jut the one)walk in to the group of crates have your back facing the stack of crates(2) and that lonly crate lay down and get your binocks out and slide in side of it then once in side of it u can get on your knees and go to your gun and kill , this also woks at the crates in front of the wearhouse put the crates that have 2 u can not get on your knees only your belly
    MP01 River
    Day Docks
    the south of the map, where you spawn at next to the craters down there, there is a small boxed crate, you need to equip your binocs for this though and get on the ground facing right into the crate, then just move right through and you have a whole area to run around back there, you can walk into anything and pick anyone off you see, when not inside a big or small crate, you can be shot and killed, and you also show up on the radar if they have sensors.
    Embassy:
    Goto the alley just north of the bank. Turn around and face the van. The wall just to the right is were people usually do the peek and shoot. Well I have only seen this once but somehow you can manuver just right and get into the wall facing the van and see right through to the van and take your time picking the person off behind the van. I have done this once and it is very difficult to do, I had a friend with me and we tested it again and I couldnt do it but he got it. But mostly you can only see the area right by the bank and nowhere else.
    Night Docks
    The closed Garage to the East of the Submarine Bay. Crouch directly in the center and then turn around so your back is facing the garage. Walk backwards while crouched, when you can't go back any further, stay in the same spot and turn around 180. Now look down and line up your crosshairs on the line where the ground and garage meet. Now lay down. Try crawling in while humping really quickly. You should be able to make it in there rather quickly. You can not be killed in here by explosive or projectile. I tried this while in mission mode and I could not see the enemies in the Missle room but my crosshairs could lock onto them and I could shoot them, but otherwise they are invisible. Probably the same for a real player. Also you cannot see some of the things in the missle room or sub bay. Very deadly glitch. Watch out for it.
  14. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Embasy - 02
    At the entrance to the embasy on the west side there is a gate which is not fully opened. If you lie down and crawl between the gate and the wall, once in lean to the left and you will see through the wall past the busses toward the alley next to the garage
    vilnius 01-i found this myself!!!!! go to the middle section that splits left and right (if you are by the gates) go to the right. go between over to where the pillars are and go to the top stair and lay down. if done right, your body will tilt down into the stairs, and you will be completely invisible. if done wrong, you can still be seen. it is hard to know if you are visible or not tho, so i doubt most people will try to use it. took about a half hour to do. i suggest trying it in versus mode (or whatever its called) so you can see on the other screen screen how you are doing it.
    M11 POW Camp - 01
    MP06 Castle - 01
    Embasy - 01
  15. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Training - 01
    Training - 01
    M03 Rail Road - 01
    M11 POW Camp - 02
    MP06 Castle - 03
    MP06 Castle - 04
    MP06 Castle - 05
    Night Docks-01
    Night Castle - 01
    Embassy 02
    Villiage 01
  16. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Village 01
    Training 02
    THE MOUNTAIN 01
    Day Castle
    mp01 river
    Embassy
    When you go through the garage toward the embassy, you can lay down on the left side peaking your head out. You can shoot people, they can only shoot you from behind.
  17. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Embassy:
    if u lean left at just the right time while in the middle of going from the squat position to the lying down position, u will have a slightly higher visibility but still wont be seen because to the opponent ur lying down completely
    Night Docks
    Vilnius
    enjoy later guys
    embassy
    MP06 Castle 04
  18. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Training 01
    MP06 Castle 02
    well there r several there u just got to be fast on getting there and getiing in the doodoo ok to do this glitch u cant have your gun in hand to do it u need your benocks here is how u do it k its shocking............... If u respawn next to the office go to the crates in the midlle ally way out by the road u will c a crate (not the one that has two, jut the one)walk in to the group of crates have your back facing the stack of crates(2) and that lonly crate lay down and get your binocks out and slide in side of it then once in side of it u can get on your knees and go to your gun and kill , this also woks at the crates in front of the wearhouse put the crates that have 2 u can not get on your knees only your belly
    MP01 River
    Day Docks
    Embassy:
    Night Docks
    The closed Garage to the East of the Submarine Bay. Crouch directly in the center and then turn around so your back is facing the garage. Walk backwards while crouched, when you can't go back any further, stay in the same spot and turn around 180. Now look down and line up your crosshairs on the line where the ground and garage meet. Now lay down. Try crawling in while humping really quickly. You should be able to make it in there rather quickly. You can not be killed in here by explosive or projectile. I tried this while in mission mode and I could not see the enemies in the Missle room but my crosshairs could lock onto them and I could shoot them, but otherwise they are invisible. Probably the same for a real player. Also you cannot see some of the things in the missle room or sub bay. Very deadly glitch. Watch out for it[/b]
