I just had a PS51D550 delivered a few hours ago and the pair of SSG-3100 glasses I have are, based on only brief impressions so far, pretty comfortable to wear and I can't really see the battery change and manual power on/off being a big annoyance (at least if the battery lasts anywhere near as long as I've seen people suggest).
However, aside from being significantly uglier and larger than I had expected based on photos, at the outer edges of the glasses the 3100 reflect the daylight seeping in through the closed window blinds behind my chair, and while I could mostly ignore it it was still a bit distracting (it will be a few hours yet before I can try the glasses for night time viewing).
I just visited a selection of stores, hoping that it would be possible to try on the 3300 (both GR and CR) and 3700, but unfortunately none of them had the 3700 in stock and they were entirely unwilling to open one of the (clamshell) packs so I could try on the 3300. I'm sure they'll say the exact same thing about the 3700 once they get those.
I frankly didn't feel particularly inclined to spend more than twice as much on a pair of 3300 as I did on the 3100, only to risk coming home and find out that they weren't any more comfortable and perhaps just as prone to be slightly daylight crippled due to reflections (they don't seem to be as wide as the 3100 though, so I'm thinking that perhaps they don't stick out enough to the sides to cause reflections).
Has anyone here tried several or all of the new Samsung glasses and care to weigh in with your opinion on comfort level and various pros and cons?
I did find an extensive post on another forum a couple of weeks ago that ranked them like this from best to worst: 3100 > 3300 CR > 3300 GR > 3700.
But I would love to hear more opinions before I decide if it's worth buying the 3700 or 3300 without trying them on first.
