Glasses Cleaning Cloth
Warnie
Guys I was wondering if you could use a regular glass cleaning cloth to clean the ipad screen? I think my local tesco have an opticians so that would be easy to source or can someone recommend any other type of cloth I could find in store?
Thanks.
NewBeetle
Thanks.
I use the blue suedette type thing that comes with iKlear.
Works great, glasses cloth would be fine though I'm sure.
This I guess
http://www.klearscreen.com/detail.aspx?ID=7
EwanSuttie
Glasses wipes work perfectly on the iPad. Especially if you have hundreds of the things lying round the house like I do.
I have a few new iMacs at school that have little Apple logo'd black square cleaning cloths that I have acquired. :smashin:
chukwe
I went to a bigger Tesco store today & bought a product for cleaning LCD & PLASMA screens called "foam cleaning pad" for £4.99.
It removed the fingerprints and has an elegant design in which the spray bottle is stored inside the wooden foam
aphillippe
I find the 'flat' microfibre cloths, e.g. the one that comes with the incipio feather cases, don't do a good job. They get rid of the fingerprints but leave the oil on the screen, so it gets very smeary. The more fluffy microfibre cloths are better. They seem to take the oil off the screen better.
What is this new material? I don't fancy wiping my £500 iPad screen with wooden foam! :D
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
