Glass stand or similar for a plasma, recommendations?
J
JASYMORR
Hi, going plump for either a 37" or 42" plasma very soon and was wondering could anyone point me in the right direction for a good floor stand from whatever supplier. Thanks :thumbsup:
J
JASYMORR
Cheers for that. I'm a fussy so and so though can't really see one on there I like :) Im after one to match the black new Pannys
Lufer
I just bought some soundstyle speaker stands from these guys. Good prices and speedy delivery. Only used them the once but very prompt.
http://www.standanddeliver.com/
SpaceMumps
ozzzy189
I too can`t fault www.standanddeliver.com They are superb, nice easy to use site too, and friendly helpful staff. I would recommend them to anyone.
J80FAB
I have one very similar to this one recommended by pjskel :
http://dwell.co.uk/product.php?prod=102318
though it's the one that the Dixons/Curry group sell. If you are wanting to arrange a few pieces of AV equipment on the shelves side-by-side you need to know what the width is between those 'pillars' holding up each shelf.
On mine I am unable to arrange equipment side-by-side as the thicker pillars on mine between each shelf reduce the available width.
That stand might look nice but it's only practical if you only have a few pieces of equipment or if your AV stuff isn't that wide.
I think this one is a very good buy & plenty of shelving space, shame that it's not in black though :
http://www.johnlewis.com/Audio+and+.../Television+Stands/193/230396661/Product.aspx
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
