Glass smashed inside sp50l7hx
Discussion in 'General TV Discussions Forum' started by geebee375, Feb 4, 2009.
  1. geebee375
    geebee375
    Feb 4, 2009
    19
    3
    I was watching the tv the other day when i heard glass smashing inside the set,i switched off straight away,pulled open the bulb tray thinking is was that ,but it was fine .any ideas anybody i could see bits of glass in there but not any big bits,the tv is three years old so no warrnty.
  2. JayKay1967
    JayKay1967
    Sep 2, 2006
    98
    +10
    there should be a thin piece of glass between the bulb and the colour wheel. You have to view this from behind the set to see it. If that has shattered then you could be looking a future problems very soon.
    Jay
  3. geebee375
    geebee375
    Feb 4, 2009
    19
    3
    There is a thin crack across abit of glass about 40mm square in front of the bulb but nothing is missing from it,wat is the ballast made from is that glass as well?coz it made quite a noise when it broke.
  4. geebee375
    geebee375
    Feb 4, 2009
    19
    3
    i take it no body knows wat the glass was that could of smashed inside my tv was then.
  5. aflowers001
    aflowers001
    Jul 23, 2005
    11
    To the best of my knowledge the glass between the bulb assembly and the colour wheel housing is expected to have a thin crack in it. It is part of the design. It has been mentioned on other SP50 related posts over the years. I definitely have it and it makes no difference to the picture quality.
