Glass mount powered, external DAB antenna ?
Discussion in 'Music Streamers' started by dirk.diggler, Aug 30, 2005.
  1. dirk.diggler
    dirk.diggler
    Hi I'm looking for a glass mount powered external DAB antenna to connect to a Blaupunkt Woodstock DAB 52 head unit. Does anybody know of a supplier?
    I intend to install this to either the front windscreen above the rear view mirror or on the rear quarter light window. Does anybody have any advice against this?
    :lease:
  2. Gazpilot
    Gazpilot
    Aug 24, 2004
    82
    Just fitted a DAB unit to my Alpine and was swayed towards an extenal aerial as I was told the glass mount lose to much signal. It was quite expensive (£80) but well worth it, its a DAB/FM conbined powered.
    You can find all types here Clicky Clicky
  3. dirk.diggler
    dirk.diggler
    Hi Gazpilot thanks for the advice & info. Sure looks like a top product but its more than I can afford :eek:
  4. Scunnyjack
    Scunnyjack
    Aug 17, 2005
    5
    Bought glass mount aerial with my woodstock52 from"Bluespot Audio"but aerial is available on its own for about £39.99,comes with lead about 5mtrs long.Mine's mounted top centre of the rear screen & the signal is so good that I rarely bother with the antenna!
