Glass lenses for sony 1031Q ????
Discussion in 'Projectors, Screens & Video Processors' started by monty, Jan 18, 2003.
Thread Status:
Not open for further replies.
  1. monty
    monty
    Has anybody got any glass lenses for a sony1031q as i'm looking to replace the plastic one's, also can any recommend a what sort of gain screen would be suitable for this projector ???
    cheers
    M0nty
  2. Koldby
    Koldby
    Look at this URL:
    http://www.audiovideo101.com/shopping/themarket/displaycategory.asp?catid=12
    He is selling BRAND NEW HD-144 glass lenses and color corrected too!!
    The freight is rather costly though.
    I have just ordered a set for my SONY 1030QM.
    In a completely darkened room a gain of 1.3 would be fine. Higher gain is good for tube wear, but tend to be more expensive and tend to be hotspotting. Lower gain - darker picture or more wear.
    good luck
    Koldby
  3. monty
    monty
    thanx for the info !!
  4. Koldby
    Koldby
  5. tonymott
    tonymott
    I have a set of hd6 lenses which I will sell for £200 .They have a 6"distance between diagonally opposite fixing bolts.New price £700...each.
Thread Status:
