Glass door (turn from clear to tinted)
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by MickB, May 30, 2005.
  1. MickB
    MickB
    May 15, 2004
    486
    28
    Hanslope,Bucks
    +30
    I'm trying to find a suitable product to cover a clear glass door to a very dark tint to hide the gear, but allow the IR remotes to operate.
    the size is approx 65cm x 125cm, I've tried using the film used in car windows, but its extremely difficult to use on a large area.
    any ideas... :lease:
  2. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    ...I would check Halfrauds or a local Car window tinting company - even your local car parts shops will have I would expect....
    You can expect to find either a can of spray or film that you apply with water....
    Should not cost much...
    DJ
  3. shahedz
    shahedz
    Apr 26, 2005
    10,302
    +1,231
    i agree with Dj black. but would say use the film, as you get an even tint and its easier to apply, also should you wish to remove its a lost easier than the spray.
  4. AMc
    AMc
    Nov 20, 2000
    5,724
    Near Norwich
    +2,263
    We frosted our front bay with window film from a glazing company.
    It wasn't that pricey at around £30 for about 3 metres by 1.5m and wasn't 'dead easy' to apply but we managed it without bubbles etc.
    Give a couple of glaziers a call and see if they have a tinted version?
