Gladiator: Whos buying a R1 copy?
Discussion in 'Movie Forum' started by Jon Weaver, Oct 27, 2000.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    As Gladiator is coming out simulaniously in R1 and R2 and the extras are the same, will anyone still buy the R1.
    The price seems to be the same, and it could be argued that the R2 (PAL) version looks better, so is there a reason to buy the R1 version?
  2. Popester
    Popester
    I've gone for an R2 copy.
    Look at it this way, if we all buy the R2 copy then it will vindicate the studio's decision to release (almost) simultaneously and maybe we will see a lot more of this in the future instead of waiting months for a post US release.
  3. Ace007
    Ace007
    From what I've heard the R1 copy has slightly MORE extras than R2.
    I would buy R1 anyway just in case of BBFC cuts.
    As far as I'm concerned R1 wins MOST of the time but when R2 is clearly better then I go for it.
  4. Ace007
    Ace007
    Popester,
    Had Gladiator been released at different times then I would have had a R1 copy in my hand a long time ago....instead of waiting for them to release it at the same time as R2!
    They did'nt move the R2 release forward they pushed the R1 release back!
  5. Guest
    Cheapest UK price I've seen is £19.99, Amazon.com are doing the R1 for $17.99. I always get discs 'in bulk' so never pay more than $3.00 per disc S&H.
    R1 may have a touch less resolution (I've never really noticed with anamorphic material), but plays at the correct speed, the price swings R1 for me.
    Also, may upgrade to pro-scan next year, there is no non-computer PAL equivalent yet.
    "I amaze myself sometimes, I'm always thinking"
  6. Ace007
    Ace007
    Pete,
    Good point if you are going to upgrade to Pro-Scan at some point than go for R1!
  7. neilbennett
    neilbennett
    I'm going to buy the region 1 version, I generally find region 1 to be far superior to region 2, as most people do. But would welcome reading reviews/comparisons. Even if they are exactly the same I’ll probably favour region 1.
  8. Ace007
    Ace007
    Region 1: 25min of Deleted scenes - 7min Montage of unused footage
    Region 2: 20min of Deleted scenes - can't see any Mantage mentioned!
    You choose?
    Info from play247 complain to them if it's wrong (hehehehe [​IMG])
  9. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    +739
    THe cheapest I have seen so far is Play at 17.99 for the R1 and R2.
    From what I have read there is NO difference between them.. Infact, the R2 has more subtitles than the R1, so infact it has more.
    Although I have no hard evidence on this, I have always found the picture of an R2 disk to be better.. So, on that front surely the R2 would be the best choice.
    So its down to the extras and film content, and I have been reliably informed that they are both IDENTICAL!
    Check out 'http://www.dvdrumble.co.uk/', which is a site which compares R1 to R2s.
    They have Gladiator down as a draw, as there are no BFCC cuts and no differences in the extra.
    For a change, its going to be hard to justify buying a R1 disk.
  10. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    +739
    From DVD rumble.. The R1 and R2 have:-
    - Commentary by director Ridley Scott, editor Pietro Scalia, and cinematographer John Mathieson.
    - "HBO First Look" Making Of Documentary
    - The Learning Channel's "The Bloodsport of a Gladiator"
    - 25 minutes of Deleted Scenes with director's commentary
    - 7 minute montage of additional unused footage
    - Interview with Oscar nominated composer Hans Zimmer
    - A "Lucious" production diary written by actor Spencer Treat Clark.
    - Behind-the-scenes photo gallery
    - Storyboard comparisons
    - Production notes
    - Original theatrical trailer and television spots
    According to this source, they are going to be EXACTLY the same
  11. Popester
    Popester
    Ace
    Yeah, I would have gone for R1 too had it been earlier. However one point not mentioned is that few of my family and friends have multi region players therefore I can lend them my R2 copy which I know they will appreciate.
    As for the extras - I can't see any difference at all.
  12. mysteriousjimmy
    mysteriousjimmy
    I will be buying R4 and from reports from a couple of web sites here in OZ we are going to get PAL progressive scan......
  13. Guest
    Region 1 Gladiator for me too.
    It's cheaper and I like giving my business to companies that don't shaft me (although Play and Blackstar are excellent for Region 2 to be fair -so I guess it's just because it's cheaper then).
    Gary
    A Phased Plasma Rifle In A 40 Watt Range®
    My DVDs
    [​IMG]
  14. Ono
    Ono
    Oct 18, 2000
    1,642
    London
    +221
    Region One.
    Why? Cos if this RCE thing gets any more advanced and we are FORCED to chose only R1 or R2 then I know which one I'm sticking with!
    Have about 100 R1 discs and about 20 R2. May even consider not bothering with R2 anymore actually.
  15. Guest
    I'm getting the R1 version, the main reason being that the extra 4% speed up with R2 UK discs means that I'm not watching exactly what the director intended (There are some scenes shot at 60fps which at the cinema seemed like slow-mo shots which won't on UK disc). Also can anybody confirm that the DTS on R2 is 5.1, whereas the DTS on R1 is 6.1 ES? My theory is this, they will use the orignal 6 channel master for 5.1 (6 ch, 20 bit master) but use a new 7 channel, 24-bit master for 6.1. If so does that mean that the R1 DTS ES will sound better? I leave it to you guys....
  16. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    R1 for me too. I'll never pay HMV or Virgin £20 for a (usually) inferior R2.
    "Open the safe paps. If you don't open that on the count of three, 1, 2, - fudge Me"
    Website coming soon
  17. PoochJD
    PoochJD
    Aug 28, 2000
    11,001
    Norwich
    +1,861
    I'm going for Region 1!
    Despite the R1 DVD having less subtitles (so what!) it does have the extra Dolby Digital 2.0 Surround sound soundtrack, which can be useful for those who don't have a full 5.1 set-up, like myself.
    Plus, you can guarantee that come November 21st, Region 1 users will have the DVD in their hands! Region 2 users, will be left standing, due to "leaves on the line, so we couldn't get the disc to the shops on time" or some other similarly lame excuse, that we always get for "late R2 arrivals".
    How many of you have gone on the announced day of release for R2 discs, and been told it's been "put back" or "delayed" or some other such junk?! Region 1 users won't get that kind of p*ss-poor treatment unless there is something major, like the company wanting to add additional material to the disc. That's the only excuse they ever use, otherwise the disc is available exactly when it was promised! (Maybe it's because Britain is reknowned for being useless at time-keeping?!)
    Pooch
    [This message has been edited by PoochJD (edited 27-10-2000).]
  18. PoochJD
    PoochJD
    Aug 28, 2000
    11,001
    Norwich
    +1,861
    Popester wrote:
    "Look at it this way, if we all buy the R2 copy then it will vindicate the studio's decision to release (almost) simultaneously and maybe we will see a lot more of this in the future instead of waiting months for a post US release."
    It won't happen, Popester. This is a trial thing, and there's a high chance that R2 users will find they don't get the disc on the same day as all of those who have pre-ordered a R1 version. You'll get given some crap explanation for the disc not being available, and have to wait a couple of weeks, more than likely, seeing as that's what happens with every other UK R2 DVD release!
    Plus, apart from this DVD, there's only one other DVD I can think of, that has had the exact same R2 treatment, as the R1 equivalent, and that was for the 2-disc set of "Magnolia". Every other time though, we get shafted here in the UK, and I'm fed up of it!
    Pooch
  19. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    Region One all the way! Due to the following reasons
    1) I get it early
    2) Its Cheaper
    3) Better Quality Disc and Packaging
    4) Its Region 1
    5) I hate 50Hz Flicker
  20. Matt
    Matt
    Jul 13, 2000
    775
    Cambridge
    +19
    Gotta be R1 for me, that soundtrack HAS to be at the correct pitch.
  21. YETi
    YETi
    I ordered Gladiator R1 from Play247 some time ago and I am sticking with them.
  22. hank hill
    hank hill
    R1
    cheaper!
    I'm gonna catch them sucka's if its the last thing I ever do.
  23. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    R1 as always. R2 have got a lot to answer for!
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  24. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    yep region 1 for me too.
    cheers.
    And the monkey flips the switch.
  25. StuartBooth
    StuartBooth
    R1 - this has a DTS ES 6.1 soundtrack that the R2 is missing (ES/EX/discrete, I can never remember which is which! <LOL> ).
  26. Guest
    There is no option!
    REGION ONE ALL THE WAY!
    No matter what, even if they look like they are exactly the same according to press releases and reviews, there is always something there that makes the R1 disc better.
    Whether it be that there is acctually something missing from the special features on the R2 or 4 disc compared to the R1, or that it is always the case that the menus and the packaging on the R1 one look a lot better in general.
    The R2 and 4 discs will probably come out in those clear, big goofy cases that we are so used to, but of course the R1 disc set will have some sort of version on the Armary(?) cases that we all love. Once again, my bet goes on the R1 set.
    R2 and 4 had better start doing something pretty special soon to make me change from always buying R1.
    Of course there are a couple of small exceptions to this rule......
    That's pretty lame Milhouse!
  27. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
    I've pre-ordered Gladiator on Region One from Play247.com. The cost is £17.99 delivered (Recorded Delivery). Money not taken from credit card until shipped. I posed the question (R1 or R2?)on one of the newsgroups and the vote was that R1 would be better on balance. It was a close run thing though.
    Anyone thought that the popularity of Region One might have something to do with the fact that it's slightly naughty? Rember CB radios? They died a death when the legal bands came into force! People like to be rebels on the quiet!!
    Regards
    Jim [​IMG]
  28. Jesus H
    Jesus H
    how's it naughty
    other than avoiding Mr Taxman
    'This one's got a bad mmooooooooooooooooootivaaaaaaator (in a very camp voice)'
  29. Guest
    BTW, I'm still going for R1 all the way. I have heard though that the R2 will contain a DTS-ES track. This begs the question which one? A 5.1 matrixed ES or 6.1 ES? All I have seen is 5.1 on DVD sites information.
