Gladiator DTS ES?
Discussion in 'Movie Forum' started by Wiggins, Dec 7, 2000.
  1. Wiggins
    Wiggins
    Aug 31, 2000
    376
    Doncaster, S.Yorks, England
    +19
    Hi there,
    I'm currently looking at buying an amp/reciever and a set of speakers, and the whole DTS thing has got me confused.
    On the back of the region 2 release of Gladiator it shows a DTS ES logo.
    Does this mean that I will not be able to get DTS sound on an amp that only has DTS available?
    The reason I ask is that the only amps with DTS ES available are all way beyond my price range.
    Any help would be appreciated.
    Alex W-G
    [email protected]
  2. Guest
    DTS-ES in any form (Discrete, Matrix 5.1) is backwards compatible with all DTS Decoders so you have nothing to worry about. If you have a 5.1 decoder only then it folds the rear centre into the Left and Right surrounds (Both for Discrete and Matrix 5.1)
  3. Wiggins
    Wiggins
    Aug 31, 2000
    376
    +19
    Cheers for the info.
    That's cleared up all my worries.
    Thanks.
    A Wright-Gibbins
