Gladiator 3:16....The Results
Discussion in 'TVs' started by fleagledog, Jan 7, 2005.
  1. fleagledog
    fleagledog
    Dec 31, 2004
    61
    As I said in another thread, I decided to get to the bottom of this bluring and so have tested this on 4 different systems including the Tosh. Sony DVD with small CRT, Panny portable DVD with 9 inch LCD screen, PC with Power DVD and the Tosh.
    My first problem was deciding what the problem was. I had 2. The worst for the Tosh was what I would call the 'painted on beard' problem. This I only saw on the Tosh. After some tweaking I found that it was down to 'over processing' My denon 2200 dvd player has a dark black setting and a light black setting. The tosh also has black stretch. By setting the player to light black and the tosh to black stretch on; voila, the problem vanished. Also turned the sharpness down to a negative value to get rid of the DVD edge enhancement (part of the mpeg processing). Happy so far. The second problem (which I presume we are talking about) of the bluring during his movement down the line occured to some extent on every system that I tested. The reason that it may be more pronounced on the tosh is that the image is sharper, therefore the effect more pronounced, and of course the screen is bigger and very bright. I have seen this effect in the cinema sometimes and it almost makes you feel sick.
    My conclusion for what it is worth is that the film was shot this way and, bearing in mind that I saw it to some extent on all of the other systems, is just enhanced on the tosh. I think that mucking about with the sharpness did improve things.
    My second conclusion is that I'm never doing this again becuse now I know 3:16 off by heart and will probably dream about it. Hope this helps in some way.
  2. dalespitfire
    dalespitfire
    Dec 3, 2004
    591
    +8
    Nice work fella :smashin: :clap:
    Made me feel better anyway (having just parted with the wedge) :D
  3. lee31
    lee31
    Well don lad, although I actually dont see this on my Tosh I always presumed it was something to do with Gladiator itself, also may be the fact that I have a Panny S97EBS, fiddled with settings for about an hour & got it just the way I like it.
    I will check later on xbox (through components) & see if I get a defferent result
    Well done anyway, Im sure you may take a weight off Phunts shoulders
    Lee
  4. mort
    mort
    Sep 5, 2002
    102
    wigan
    appreciate the effort youve made fleagledog :smashin:
    i was thinking the same as lee that it might be the film itself ill have to try it myself next week.......i'll have to go buy gladiator first though :blush:
  5. phunt
    phunt
    May 8, 2003
    419
    +5
    Well now that more and more people are seeing the same thing as me im starting to live with it a bit easier.Ive also come to the conclusion that it is the quality of the feed and heres why:-
    A couple ov days ago before i got my sammy 945 i watched The Band of Brothers bonus disc on my Toshiba SD330E dvd player through component.At the start of the documentary there is lots and lots of slow panning ov the old geezers giving interveiws against a black background.Now at the time i had to turn it off because the blur thing was too much to handle.So as i knew i had the TV engineer coming round this morning i got the disc out last night and decided thats what ide use to show him the effect.I stuck the disc in the sammy and for the life of me i couldnt get it to blur LOL.I even tried turning the black stretch on and the contrast and brightness down to force it but not a sign.I was pleasantly suprised.So i stuck gladiator in skip to 3:16 as you do and BLUR.So yes i agree.....the disc itself maybe partly to blame.Also my QED AV2110 scart lead turned up and that seems to have improved the SKY+ blur a bit along with the PACE replacement.:).So all in all its getting there ;)
  6. phunt
    phunt
    May 8, 2003
    419
    +5
    Oh by the way...My Black Hawk Down superbit arrived today aswell so im just gonna sit down and watch it now...Ill report results :thumbsup:
  7. maidstoneman30s
    maidstoneman30s
    Apr 21, 2004
    155
    16
    not in maidstone, hehehe
    fleagledog,
    Great information on this. Still having a play with my S97 and tosh settings.
    LEEE, what are the most important settings you have changed on the S97????????? or am i asking for tooo much. Just a couple, to see if they co inside with my settings
  8. n00b
    n00b
    Nov 27, 2004
    315
    +17
    thanks for the info dog, this will def help me make my decision regarding the set, the painted on beard was worryin me :thumbsup:
  9. lee31
    lee31
    My FULL testing of Gladiator 3.0 to 3.30 - ok only 30 seconds of play on
    Panasonic S97EBS Via HDMI & Tosh - NO BLUR
    Pioneer DV646A Via Scart & Tosh - NO BLUR
    Philips DV710 Via Scart & Tosh - NO BLUR
    Xbox Via Hi Def Components & Tosh - NO BLUR
    3 different DVD players in 2 x PC's - NO BLUR
    Sorry lads, really tried to find a blur, couldnt even see one from 12" from the Tosh !
  10. dalespitfire
    dalespitfire
    Dec 3, 2004
    591
    +8
    Interesting reading mate..... :) I await mine eagerly now. :clap:
    Looks like this is going to rumble on though......At least you seem to be immune :laugh:
    Seriously though, you reckon that you just don't see it or isn't it there?
  11. phunt
    phunt
    May 8, 2003
    419
    +5
    Sorry M8 but.......Shoulda gone to Specsavers :cool:
  12. dalespitfire
    dalespitfire
    Dec 3, 2004
    591
    +8
    :rotfl:
    Hope I need to!
  13. lee31
    lee31
    100% not there, I will try & video it tonight with digi cam & see if I can get it on the web
  14. bassett
    bassett
    Nov 26, 2004
    Nice work dude!
    This was the only issue preventing me from buying a Tosh and I began to reconsider a plasma. Not any more. I'll be putting in my order at the end of the week !!!
  15. lee31
    lee31
    Just tried to video it - no good, digi cam is useless :thumbsdow
