springtide
Had just about enough of WHS. Love the functionality and simplicity, and it works really well backing up our three PC's in the house with the Lights-Out app - waking the PCs up, backing up and then shutting down the client.
BUT... For some reason (again - third time).. WHS has stopped working... The WHS services fail to start with unknown errors - meaning that once again I can't backup the backups - and reinstall and reimport.
Also have had a couple of H/W failures - which seems to render the box completely useless.
I have tried taking 'images' of the base install (as a reinstall takes ages as it doesn't recognise a lot of the hardware) with an old version of Acronis - but if you restore the image - all drives get a drive letter and the console is broken.
The Atom based board that I have can be a little slow for a number of other things that I 'serve' from it, so have just ordered for a low end i3 ITX. The Atom 330 doesn't support any of the VM CPU tech - so no chance of testing as well as one of the memory slots is now dead... so that board will be RMA'd once I have the new system up and running (I don't like no backups)
I do have another copy of my data elsewhere.. so just looking for a hassle free - set it up and forget system (which is why WHS is great - it reports when things go wrong)
My options....
1) Run WHS as a VM - under ESXi or Xenserver.
Xenserver seems preferable as I get access to the server and can schedule a shutdown (and use the BIOS - start-up at time option). With WHS running as a VM, Ican take snapshots - so recovery would be easier.
2) Switch to using FreeNAS, Openfiler, unRAID, Windows etc (native or under a VM) and use another backup application (Acronis maybe?) to backup to a network share. If native, I like the idea you can run FreeNAS from a USB key - and the data is kept separate.
I have used online backups in the past.. but I need an account per PC as well as not wanting my huge power sapping desktop on 24/7 to get my backups uploaded (have around 1.5TB of data currently) - so have ruled this out.
Anyone else have issues with WHS - or have I been very unlucky? Also, anyone running WHS as a VM?
After so much faffing with WHS and when it goes wrong you can't just deal with plain files to recover.. I'm starting to think that the NAS solution has advantages.
I know a new release of WHS is due.. and have access to the beta s/w.. but don't like running beta s/w for my backups.
Open to opinions....
My options....
