Given up
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonjonjon, Aug 5, 2004.
  1. jonjonjon
    jonjonjon
    Jul 13, 2004
    75
    +3
    Well I've sent back my Toshiba rdxs32. Yes, it was a great bit of kit, picture was very good (though not as good as my Sony dvps 715), recording and editing got 10/10.
    But, how ever hard I tried, I couldn't ignore that bloody fan. Yes I could have tried to lessen the sound by fitting a quiter fan, or a thermisitor, or maybe I could have bought a new glass fronted cabinet. But in the end I wasn't happy paying £400 for something that wasn't quite 100%.
    So i'm going to wait until something 100% quiet comes out (like my Sony DVPS 715) and if that never happens, then I'll never own a DVD recorder.
    Saying all that I've decided to order Sky+ with multiroom. And yes I am well aware that the unit will more than likely be noisy. But this is only going to cost £149, with free installation and an extra £10 subs a month.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    So in 25 months (and £400 later) will you still be happy with it? :)
    If you don't want to archive to disk Sky+ is a better choice for home recording than any DVD recorder. You can always add a HDD/DVDR combo later if you so wish (the upcoming £1300 Sony and Pioneer models will probably be fairly silent). So you have probably made the right decision.
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    :rotfl:
  4. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,537
    38
    Nottinghamshire
    +23
    Or if you did want to archive to disc then a silent Philips dvdr can be had for £149;)
  5. bobbles
    bobbles
    Are you sure you didn't have a faulty model. I sit around 4m from mine and I really can not hear it unless i really try without any other noise.
    I have sky+ and the HD is certainly noiser.
