give me an idea please.
Discussion in 'Projectors, Screens & Video Processors' started by zcaps57, Jan 7, 2002.
  1. zcaps57
    zcaps57
    Hi.
    I now have to install my 11HT.
    Tomorrow, I'm gonna buy a screen(hopefully Da-Lite Cinema Vision), a ceiling mount kit, and 15M long component video cable.
    How do you guys who owns a projector install these kind of things?
    Do you drill walls and install them on your own?
    or do you pay "professional" guys to do the installation for you?
    I have no idea, since I've never done drilling walls or installing a projector, anything like that.
    Can somebody give me an idea how you installed it and what you found difficult?
    Any comments, advice would be greatly appreciated.
    Thanks.
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i hung my crt myself . in comparison insatalling an lcd pj should be a walk in the park
    the only real problem i had was locating the studs . i tryed using a stud finder but to make sure i was in the midle of a stud i cut out a small section of plaster board after findin the general position
    the other thing is to make sure it is perfectly square with the screen and centered. the best thing is to put up the screen first. then mesure the correct throw dist from the center of the screen .then to make sure it is centered you mesure from both sides of the screen to the point the projector is going to be . if it is th same dist from both sides then you are centered
  3. zcaps57
    zcaps57
    Thanks for the advice. :)
    I appreciate it.
  4. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    If it's any help, I have the same problems! I'm about to order a VW11 but I'm not sure how to run cables. I have 3 options:
    1. Run cable up the front wall into attic and over to a ceiling mounted projector.
    2. Run the cables under the carpet and up a wall to a bracket (maybe standsunique wall support)
    3. Put projector on a desk and put cables under a rug!
    2 seems like the best option right now as it involves minmal time and effort!
    Not sure on which screen yet, either the Da-Lite Model C or Draper Luma. What made you choose Da-Lite Cinema Vision?
    Where did you get your VW11 from (and how much) if you don't mind me asking!
  5. zcaps57
    zcaps57
    Hello.
    I ordered Da-lite matte white instead of cinema vision.(talked to a gentleman called Walter Stewart at direkt2u.co.uk and he said cinema vision has high gain which does not quite suit the projectors like 1000 ANSI lumens. instead he suggested High contrast da mat and matte white. High contrast da mat costs 1014 GBP and white matte 278.45 GBP. They are about 8ft.)
    I went to Japan for Christmas holidays and bought 11HT.
    I paid around 3150 GBP. :)
    This..cabling and mounting projector and screen gives me headache.
    :rolleyes:
    Good luck with your 11HT purchase !! :)
  6. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Just shows how much we get ripped off in the UK! I got a better offer today of £3,299 +VAT (£3,876).
    I am going to the Bristol hi-Fi show next month so I was thinking of checking out what's on offer there before buying.... who knows, might be even cheaper by then!!
  7. zcaps57
    zcaps57
    Heh...I know. Everything is EXPENSIVE in UK.
    Nigel, if you live near central London, you are more than welcome to visit my place and see the 11HT in action. :)
  8. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
  9. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    When you say you have never drilled walls etc, I take it you mean literally a total novice?
    If so, I would pay someone to put it up. Even a handy man. The reason I say that is because there are a lot of little tricks to getting good holes, secure fixings etc that would be very handy to know. I know it sounds 'superior', but trust me, the last thing you want to do is end up with holes all over the place and you stood screaming in the middle of the room.;) I know. I learnt all my DIY skills over time. It's not always as easy as it looks.
    Also, do you have all the tools? You'l be surprised at what you'll end up needing. I usually have about 4 toolboxes open just to hang a picture.:D
    A handy man would charge a fee and you would at least know all is secure.
    Sorry to sound neagative, but it might be the best option if you really don't know DIY.
  10. zcaps57
    zcaps57
    ono.
    You're right. I'm a total novice. :blush: And I do not have any tools.
    Does anyone in this forum live in London area??
    I live in central London, and if someone can help me installing my projector, I'll pay.
    BTW, thank you guys for advices.
    I really appreciate them! :)
  11. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    I live in Lewisham, South London..... and I have a set of screwdrivers!!
  12. zcaps57
    zcaps57
    Oh, good news. :D
    Nigel, have you done drilling and these kind of work?
  13. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Not done drilling since metalwork classes at school!
    My dad's a carpenter/joiner and I was hoping he will help me fit mine when he visits in March.
    Might need to run cables and put rugs over them until then!
  14. zcaps57
    zcaps57
    Hehe. :)
    alright. I've just been to Shasonic in Tottenham Court Rd, and the guy who deals with installation will give me a call soon.
    Hope it's not too expensive. :(
  15. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    Nigel/Eric
    At last, some South London forum members! I've been off the forum for a while and just logged back in (bored at work ;) )
    I live in Oval and installed and set up my own system, including wall mounted speakers and fixed screen (I like to think I'm handy with a drill :eek: !!).
    If either/both of you would like to get in touch for help/chat/watching movies then just drop me a line. It would be great to share the joy and pain of the HC experience with some locals!.
    I've sent you both private messages about a spare Da-Lite screen I've got.
  16. zcaps57
    zcaps57
    Hello, Sam. :)
    I live in central London. 3 mins away from Tottenham Court Rd.
    And yeah.. it would be really nice to share our HC experience.
  17. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Before you put your projector on give the mount a good yank to make sure it stays there.
    I would hate to see an LCD projector get broken.:devil:
    No, really I would.
    I hang from every mount I put up then do a few chin ups. (do mean only a few!)
  18. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    Trust me he does.............!
    Only trouble is i had to call a builder to come round and get the "Bow shape" out of my flat roof!. :D :D :D
