Give Me a Clue..
Michael_Hunt
Established Member
...What the bloody hell is happening with my pc both my dvd drive and my cd writer have stopped detecting discs I've tried removing and installing and still nothing I havent done anything to cause a problem not that I'm aware. PLEASE PLEASE HELP ME!!!
:confused: :confused: :confused:
Peter Parker
Loose ribbon cable?
Check that the secondary ide channel hasn't become disabled too - it sounds like you haver the power connection, but lost the ide somehow.
Gary.
MonkeyDonkey
Yup check your cable. Also check in device manager your secondary IDE Channel (under IDE ATA/ATAPI controllers) is being detected and is working correctly, and is not disabled.
Are your devices being recognised when your PC POSTS at boot up?
Michael_Hunt
Established Member
Worked out that both are shagged tried in another pc. All I can say is you get what you pay for. Buy **** you get ****, spend a little more.
MonkeyDonkey
Umm seems a little odd they'd both die at the same time.
What make were they?
You did use a different cable when you tried them in another PC didn't you?
Michael_Hunt
Established Member
Well found that dvd drive still detects dvd's but not cd's. The cd writer is called Everspring it was a special from Ebuyer it's 40x12x48 and was £33 plus vat. So i think I'll upgade to Plexta.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
