Girlfriend proofing the system
Discussion in 'Home Cinema Control & Remote Controls' started by gunizzle, Sep 2, 2005.
  1. gunizzle
    gunizzle
    Hi All,
    Forgive me if im in the wrong place, but can anyone recommend a good universal remote controll that will control, a dvd player, a panasonic pwd7, a sky box and a marantz 5500.
    My girlfriend is screwing as she has to pick up 30,000 remotes every time she wants to watch the tv, i on the other hand dont care, but hey thats life in AV equipment one half is enjoying the system, the other half is explaining it to the missus!!
    any suggestions!
  2. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,862
    Probably one of the Harmonies (655?) as they have "activity" buttons labelled "WatchTV", "Listen to Music", etc. Once programmed the appropriate kit is switched on & inputs selected with a single button press.
    Check out the dedicated Remote Forum if a Mod doesn't move this first.
  3. SJGIL
    SJGIL
    Jan 18, 2005
    175
    +3
    I have a Harmony 655 and the wife thinks it is great and has no problems controling the whole AV set up so would recommend one of these.
  4. UKseless1
    UKseless1
    Mar 9, 2005
    839
    28
    +36
    Yup - also have a Harmony 655 and it works well.
  5. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    :eek: If she's cheating on you for having lots of remotes, I'd say get a new girlfriend. ;)
  6. Chavvychase
    Chavvychase
    Its a good idea to have only one remote. But you are still left with the major problem of educating the gf into how to use it. I have instructed mine on numerous occasions about which buttons to press, but she still presses the wrong ones (usually accompanied by a loud oooh -its not working!). Why is it that most women seem to be able to operate complicated kitchen equipment but are generally useless at operating video equipment? :confused:
  7. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    As Crocodile has said, best to look over in the Remote Controls forum. Can one of the plasma mods move it over please.
    Price and complexity are the 2 points which you need to look at before you choose. Logitech Harmony remotes are the in thing for price and fairly easy to us. Philips/Marantz prontos are more expensive, and slightly more complex in set-up, but ultimately give you the most flexibility.
    Andy
  8. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    An unfortanate turn of phrase,perhaps.
    Moving...................................>
  9. Ged
    Ged
    Apr 29, 2002
    943
    +24
    I have just bought a Harmony 885 and it is great, I have sort of used a Marantz RC5000 for a few years but allways had to have the others close.
    We are now down to one remote and I may consider another to replace the recently aquired Kameleon 6 which I am not keen on any longer.
  10. Skeets_de
    Skeets_de
    I got my Harmony 885 today, a few rough spots but I can't reach Logitech German support until Monday. :smashin:
  11. doubledrat
    doubledrat
    Jan 24, 2004
    89
    It is not a cheap option, and it takes quite a bit of programming (which I think is part of the fun), but the flexibility of the Pronto will allow you to create a "task based" system for your girlfriend to use. For example, the front page of my system simply has 3 icons
    Watch TV
    listen to music
    turn everything off
    If the wife hits "watch TV" then another page appears which says -
    DVD
    satellite
    video
    On choosing "DVD" everything gets turned on for her and set to the correct input. She is then presented with a set of controls for the DVD player (with the added bonus of being able to control the volume on the amplifier-a completely different device, at the same time)
    With the Pronto you are really only limited by your imagination
    But they are not cheap
    I easily got the wife to agree to one by saying "I can replace our 11 remote controls with one remote control she said "Go ahead" I said "it is expensive..." she said "I do not care"!!
  12. czzer
    czzer
    Mar 2, 2005
    719
    43
    +105
    Harmony does all that, is much easier to program, and much cheaper to boot!
  13. Rambles
    Rambles
    Jul 14, 2004
    8,310
    UK
    +1,286
    I like my Harmony 885, it is a bit fiddly to set-up, but once configured is good to use - it has a help button which sorts things out if it gets out of sync, it has nice clear display and the tilt sensor automatically turns the back-light on when picked up....
  14. gunizzle
    gunizzle
    unfortunately Lisa you are probably only one of many that can understand how it works, most of us get the "oooh this is so stupid, its not working!" which only serves to frustrate me even more!
    I think a remote that says TURN THE WHOLE LOT ON and TURN THE WHOLE LOT OFF would suit perfectly! Not that im saying my girlfriends dumb when it comes to things like this!! haha
    What model of Pronto is it?? where can i get hold of one?? and finally at what cost??
    Thanks for your help people!
  15. gunizzle
    gunizzle
    also aswell, can it controll sky plus features? like live pause etc, record????
  16. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Hi gunizzle
    To get the best out of any of the more advanced programmable remotes like Prontos or Harmonys you do need to be happy about doing a little work setting it up. If you are not or are quickly frustrated I would not reccomend either to you. If all you want to do is turn everything on and off they are IMO a waste of money. The more expensive ones dont just turn things on they do things like automatically chose all the right inputs etc. A cheap one for all or similar will probably be fine for you.
    I would have thought almost any learning remote could control a Sky+ box. :)
    Regards Richard
  17. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,862
    When I posted this I hadn't actually used one. Now I have I can advise that setup is a complete lottery. If your devices are correctly configured in Logitech's database then it may well work as described. I wasn't so lucky & found it completely useless. Propbably worth a quick try as the concept sounds good if you can get it to work, just make sure you buy from somewhere with a no quibble returns policy.
  18. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    The Harmony 885 does all that ... and my system is now "wife-proofed!!"
    Its fantastic!
  19. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    But has she forgiven you for smashing up the sitting room to fi the plasma in. :D
    Richard
  20. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
    She wanted it as much as I did there!!!
    (but she does constantly say she wants a kitchen as I had my toy!)
  21. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    What are you like; a Plasma but no kitchen.
