Girder commands don't work during vob playback
Discussion in 'Desktop & Laptop Computers Forum' started by Peter Parker, Sep 6, 2003.
  1. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,181
    UK.
    +2,721
    This is a bit of a strange one - I have Girder st up to control PowerDVD, and when playing back a DVD, it works well.
    If I'm playing files from the hard drive via a playlist, when I press stop or next chapter for instance, the playback stutters slightly during the keypress, but the function isn't executed. So it seems to see the command, but more or less ignores it.
    Any ideas what this is and how to fix it?
    Cheers.
    Gary.
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    How are you getting Girder to control PowerDVD? If it's by WM_Command then i guess power DVD might have a different command for a straight DVD and a lone VOB file? That's all i could come up with.
    Sean
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,181
    UK.
    +2,721
    Not sure to be honest Sean - I downloaded the .gml file from the Girder site, then just relearnt the remote commands. so I've no real idea how it all works at the moment.
    Someone on another forum did suggest something similar to you, so I'll look into it.
    Cheers.
    Gary.
