GIGABYTE GA-MA78GM-S2H Bios Setup?
cs3007
Thought I would post this one in here, seems it such a popular HTPC board.
Can ayone help me out with what settings I need to make in the Bios as I have noticed that even the ram settings default at 667mhz not 800mhz, even with optimized defaults. I have since changed the speed to 800mhz and it seems fine.
What other settings could I change to maximize the following, without killing anything:-
HD3200 IGP
AMD 5050e
Kingston 4GB (2x2GB) DDR2 800MHz/PC2-6400 HyperX Memory Non-ECC CL5
k.jacko
Hi mate, same board as me btw :smashin:
Don't worry too much about your multiplier and dividers ratios. 1:1 is obviously fine, but i've had mine (although other overclocked rigs) at all sorts of ratios.
Basically, if it doesn't overheat and it doesn't keep crashing, you're fine! ;)
