Gigabyte 9600pro
Discussion in 'PC Gaming & Rigs' started by JimB, Jun 25, 2003.
  1. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    I ordered a 9500pro from this place http://www.home-pc.co.uk/browse.php?code=ATI9500DDR on the understanding they actually had the card.
    This morning a Gigabyte 9600pro turned up instead, this one :(
    If I can't get a 9500pro, then I was going to get a 9600pro anyway. Should I just keep the card (they have charged me £148.64 including P&P) and save my self the hassle of returning it.
    The card is sat there and I really want to pop it in my PC.
    What do you think?
  2. joecool
    joecool
    May 13, 2002
    30
    9
    the 9600pro is the replacement for the 9500pro but is actually slower than the card it replaces! you might have trouble getting a 9500pro because it is no longer in production. you can shop around you never know.
  3. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    yeah, I realise the 9600pro is slower, but since you can't get a 9500pro anywhere there's not a lot I can do.
    Anyway I installed the card last night and it looks great compared to what I upgraded from - a Vividxs 32mb!!!!
  4. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    Unfortunately, now you have installed it and it is fully functional, I think you have missed your opportunity for a refund (which you should have requested as a matter of principle)
    Still, it's a cracking upgrade!
    Big A
  5. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    Big A - I did complain & received an apologetic email offering a full refund, but since I had the card I thought might as well keep it.
  6. CENSORED
    CENSORED
    Overclock it.
  7. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    Stable at 506.25 core & 344.25 memory.
    The memory wont go over 345 without some mad artifacts.
    The core will go a bit higher but I'm still experimenting with it.
    Pretty good really.
  8. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    those speeds mean nothing (although those are good overclocks). what scores do you get in 3dmark2001se?
