Gigabeat distortion
Discussion in 'Headphones, Earphones & Portable Music' started by GizmoPower, Jul 5, 2005.
  1. GizmoPower
    GizmoPower
    Hi everyone, first post for me.
    I have bought the 60gb Gigabeat and love the look / feel etc, but on anything other than flat EQ, the sound distorts, particulary if I try to add ANY bass whatsoever.
    Does anyone else have this issue, and if so, is it something that can be fixed with a firmware patch, or does it point to an underpowered amp?
    thanks.
  2. rp92
    rp92
    Did you try to determine whether the problem is the source (the Gigabeat itself) or the headphones/earphones/speakers you're using ?
    I would suggest to try different headphone/earphones or to connect the Gigabeat (if not already done) to the amplifier of a home stereo and see whether the problem persists or not.
    Peppe
  3. GizmoPower
    GizmoPower
    Yes, sorry - I should have elaborated a little more.
    I have tried it with 2 sets of full size headphones and still get the same problem.
    Having looked at the forums on www.mygigabeat.com it seems like its a pretty common complaint from users.
    Thats pretty worrying - the flat EQ simply doesn't provide enough body to the sound.
  4. vtr2004@tiscali
    vtr2004@tiscali
    Hi Gizmo
    I have an F20, and have to agree that flat eq is best, but i do listen to some music using SRS WOW 1.
    I'm hoping that some sort of firmware update will sort out the other eq settings.
    Not much help i know, but your not alone in thinking that (in this isntance) flat is best. :)
