Ghosting on z3 any1 had same problem??
Discussion in 'Projectors, Screens & Video Processors' started by Seanshadyuk, May 5, 2005.
  1. Seanshadyuk
    Seanshadyuk
    Mar 9, 2005
    75
    Luton
    set up my z3 and faint outlines appear around objects i've focused properly and turn't sharpness all way down anyone had this problem or knows how to fix??
    could this be cos i'm using too much lens shift???
    thanx
  2. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    How are you connecting, what's the source and how long are your cables?
  3. Seanshadyuk
    Seanshadyuk
    Mar 9, 2005
    75
    Luton
    1.5m thor component from a toshiba sd140 only cheap i know but shouldn't do this surely?? its was set to progressive but ive now packed my projector away cos i was only having a little play i have to wait till i've finished the decoratin in the room. how i had it tho id shifted the picture up nearly all the way i think cud this be why? if so wen i ceiling mount it will i hav the same problem with downshift?? the lens was inline with the bottom of the image which is what i thought was correct or is it better to have the lens in the middle of the screen?
  4. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    Lens shift shouldn't cause that problem but it may be worth trying a different cable when you unpack your Z3.
  5. gingerone
    gingerone
    Dec 10, 2002
    2,307
    +237
    I've got the Z3 and on full lens shift I do not get this issue.
  6. Seanshadyuk
    Seanshadyuk
    Mar 9, 2005
    75
    Luton
    can not try another cable because i only have the 1 component cable available the other is chased down the wall into the ceiling mmm maybe it is the connection or something but i tried my ps2 on it aswell and that wasnt as bad but still kinda blurry maybe i need to fiddle wit sharpness?? i might have another look tonight
