polygon_monkey
I just got a Samsung 28" Pureflat widescreen tv, and am very happy about it apart from two little things. I notice it with the X-Box most. There was a slight green tint to the black and there is ghosting from logos and such. Most noticable on the X-Box logo on start up, there is a light band, the height of the logo from the right of the logo to the edge of the screen. It isn't a cable thing because the ghosting also appears with the tv's OSD and I RGB cables on both my Xbox and Gamecube and Composite on my PS2 and they all have the same problem. It even effects normal TV viewing, but you don't really notice it that much then.
I managed to fix the green tint by finding the service menu and playing around with the obvious values. I am unsure about what to change for the ghosting. I read that it could be related to VLS or something. Velocilty Limit ????. Can't remember. Has anyone else got a samsung (or any other widescreen tv) and would know how to sort it?
If it helps I can find the exact model number and take a photo of the problem when I get home.
