Ghosting on black bars?
Discussion in 'LCD & LED LCD TVs Forum' started by sunil1234, Dec 6, 2004.
Tags:
  1. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +121
    Just hooked up Panny E55 to Viera 32 LCD using QED PCV1 component cable and a scart (for sound/wscreen switch) and all DVDs i play seem to have a thin ghost bar line running across the entire lenght of the screen top and bottom of the widescreen modes. Have checked all connections are tight and seem ok.
    Is this normal, and if not, does anyone know if its a flaw of the telly or the dvd or the cabling?
    S
