hi there, I have an lcd monitor and a hdtv setup to my computer (hd is running at 1080p 1746x1006 through dvi - hdmi cable and the monitor is at 1920 x 1080 through dvi - vga adapter then vga cable)
currently i have a gtx285 1gb with 2 dvi out and am using them both. now normally i put a video or something on the tv whilst i'm playing games on the monitor but i have to have the graphics turned to low to play it ok.
my question is would a second gtx285 make it so i can play on high settings? or would i be better off replacing it?
also is it that thats holding me back?
i have an amd 64 x2 5600+
4gb ram
windows 7
anything else you need to know please ask
sorry for all the text and thank you in advance for any help
Paul
4gb ram
windows 7
Paul
