Gettyburg re-released
R
rimshot
I have a region 2 player, so will the region 1 disc play in my computer dvd drive? HELP!!!!!!!!!!!!!!!!
Roger
Setenza
Your PC DVD drive will have region protection.
There are two options open to you. You can go for a possible firmware upgrade on your drive, if there is a region free hack available. The downside of this is if you do it wrong or the hack is poorly made, it can FUBAR your DVD ROM drive.
Use this link to find out more:
Firmware upgrade
Or alternatively, theres this piece of software that fools your PC into thinking your drive is region free even when it's not. However, it only works with the major software players so read the small print. It also cost about $40 but it's worth it.
DVD Idle
Hope this helps.
XOD
The Best Netflix Movies and TV Shows Coming in October 2020. Tom's Thumbs.
