Getting videos onto PSP from mac
blackpants
Hi there,
Please help me. I am trying to put some DVDs onto my PSP. I have firmware ver3.30 and running an Apple laptop with osX 10.4.9. I have tried to rip from DVD using MediaFork but when I transfer the file to PSP it says unsupported data.
I have observed the naming conventions to the letter and am a bit lost as to what to do next. Anyone able to help??
louishm
you will have to rip your dvd first with mactheripper and then use to handbrake to convert to .mp4. As far as i am aware handbrake will not remove any protection on a dvd.
gerbilly
mate I have already copied movies via mac the ripper and also handbrake to convert to mp4 but i have no ideal how to get them on the psp.
louishm
you'll need to create a new directory in the root folder of your memory stick called "MP_ROOT." You'll then need to create a "100MNV01" directory inside the MP_ROOT directory. You'll put your video files in this 100MNV01 directory.
gerbilly
Sorry to be a pain, I did what you said and threw a couple of mpeg4 movies on to the psp. It looked as though it took up the space on the psp but I could find nothing on the music or video files on the psp.
I also have a strange problem when I connect the psp i-photo launches, I dont have a clue why?
Also when listening to the music through my own earphones the volume levels are very low even when it is at max, any ideals about this one?
louishm
you have to make sure the MP_ROOT etc are in the right place.
also might be better trying Instant Handbrake Here Its a simplified version that lets you select ipod/psp then click convert, no settings to mess with
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
