Getting the best out of my projector
Discussion in 'Projectors, Screens & Video Processors' started by Alexg, Feb 20, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Hi there,
    Just baught a Dell DLP projector for my new HT room, unfortunatly there are still no floor boards down yet as my dad is taking ages to lay the joists (its a new building) However I couldn't wait to see what it was like though so I set it up with a PC, and I was a bit dissapointed by the fact I had to have a dark room to get a good picture, I thought that it being a 2200 lumen projector that I could use it in the daytime but I've sinse learned that it is normal to have a dark room to get a decent image.
    How much increased gain will I get by using a screen? (currently projecting onto a grey wall)
    Even in a darkend room images with really dark scenes come out really dark, will using a screen improve this?
    The PC desktop is really bright on the screen, but when playing a clip the clip is darker, is there any bit of software which will lighten up the clips?
    Any advice/help would be greatly apriciated.
    -Alex.
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    Hi Alex,
    Most manufacturers claims for lumens can be reduced by around 40% for true real world lumens - I measured my 900 lumen Optoma H77 at 510lumens for instance.
    You also need to set up the projector to the source - in the case of a DVD player that's relatively easy to do - you use a test disk like Avia for NTSC or Digitital Video Essentials for PAL to set the black level (brightness) and white level (contrast). That way you should be seeing all the detail available without crushing it into large areas of black or white for example. Failing that, use a THX DVD that has a THX optimode on it - it;s not as agood as a pukka test disk, but it's better than nothing.
    PC levels are different to video levels - PC levels use a digital range from 0 to 255 whilst video levels use 16 to 235, so the PC can seem brighter for two reasons - one is the white level is brighter,. and two, you may have your white level set incorrectly (too low). A PC can give a far better DVD image than any stand-alone player though, so stick with it. :)
    A screen can help get the best from your projector, but the screen can be compromised by any ambient light in the room. If you have ambient light, a grey screen can help, as can a screen with gain. A grey screen with gain like the Stewart Firehawk or the Da-Light High Contrast Cinema will be the best choices IMHO unless you can remove any ambient light from the room.
    Gary.
    Gary.
