I'm a long term user of mkv2vob and have never come across this problem before so was just hoping if someone here can help me with this issue. Basically what the problem is is when i mux the file and it's completed the files play with a static/white noise sound which makes the video unwatchable. I've tried muxing two times, once with 'always transcode with DTS' and once without. Both outcomes did not solve the problem.
Can anyone tell me why this is happening, and what settings i should use to sort it out?
Thank you.
Format : Matroska
Format version : Version 2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3h 48mn
Bit rate : 11.5 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.312
Stream size : 17.9 GiB (84%)
Title : x264
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 3h 48mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 7 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 2.41 GiB (11%)
Title : DTS 6.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 3h 48mn
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Stream size : 157 MiB (1%)
Title : Director's Commentary
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 2 -lowpass 15.1 -b 96
Language : English
Default : No
Forced : No
Audio #3
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Title : Weta Workshop Commentary
Language : English
Default : No
Forced : No
Audio #4
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Title : Production Team Commentary
Language : English
Default : No
Forced : No
Audio #5
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Title : Cast Commentary
Language : English
Default : No
Forced : No
Thank you.
Format : Matroska
Video
Format : AVC
Duration : 3h 48mn
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Title : x264
Encoding settings
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 3h 48mn
Bit depth : 24 bits
Title : DTS 6.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Language : English
Default : No
Forced : No
Audio #3
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Language : English
Default : No
Forced : No
Audio #4
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Language : English
Default : No
Forced : No
Audio #5
Format : MPEG Audio
Mode : Joint stereo
Codec ID/Hint : MP3
Duration : 3h 48mn
Language : English
Default : No
Forced : No
