Getting sound ou of the TH-42PWD7BK
Discussion in 'Plasma TVs' started by Stu Ward, Jul 8, 2005.
  1. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    My Audio system has decided to throw a wobbler, so until i can get a new one i was going to use the standard Stereo speaker outputs on the panel.
    Connected my left and right front speakers to the panel and i get no sound at all.
    Is this because i am running my sky + through a SCART - Component convertor thus losing the sound feed ?
    Is there something i am missing ?
    Stu
  2. w3dal
    w3dal
    Aug 4, 2002
    4,893
    Chelmsford, Essex
    +533
    Stu,
    Dont mean to sound harsh. I assume after you had connected the speakers you turned the volume up on the panny??
    I dont have your setup so just trying to help.
    I assume you have selected the right input on your amp
    Dal
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    yes its the component converter it obnly does rgb...you need to use teh red/white stereo rca leads from the converter to the screen (or straight from sky depending on which converter you have)
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    W3Dal, don't mean to sound harsh, but Stu has correctly diagnosed his own problem. There are 2 phonos beside the component inputs on the video card. Connect then to sky and all will be well.
    Shared innovation again, Mep! :D
  5. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    Thanks mep, thats the one
    As i have the convertor tucked away i forgot that it has L-R audio inputs
    Stu
