Getting Sky Plus remote to scroll through AV inputs
Discussion in 'Sky Digital TV Forum' started by leo9, Nov 12, 2004.
  1. leo9
    leo9
    I hope there's a simple answer to this! Have just upgraded to Sky Plus. On my old Sky remote, I could scroll through the various AV1, AV2 etc. inputs by first selecting "TV" on the remote and then repeatedly pressing "Select".
    On the new Sky Plus remote, I have read up how to program for my TV (Toshiba 32WL48) but this only gives me ability to control volume and TV channels.
    Can anyone help me to get AV input selection via the Sky Plus remote? This Tosh is a new TV but the AV selection didn't work on an older Sony CRT either. This is a big minus for Sky Plus - before I only needed the old Sky remote to control most TV functions.
  2. Iain
    Iain
    May 15, 2002
    111
    Glasgow
    +9
    Hi Leo
    I have a Tosh 28zd26p, on the sky+ remote I select tv then use the help button to cycle through the av inputs.
    Hope this helps.
    Iain.
  3. leo9
    leo9
    :thumbsup: Iain, brilliant - it works! Should have posted earlier as I spent about 3 hours faffing about with codes etc.
