I've got meths, stinks like hell i heard its used to clean glass, but wasnt sure if it was ok to clean the CPU as the CPU gets very very hot.
Next time my Intel CPU needs looking at, i'll clean the CPU with meths and re-apply MX2 paste to it (as the moment after spreading a thin layer of MX2 on it, some of that moves away from part of the CPU = CPU needs a clean).
But the AMD CPU will come first.
i recommend arctic cooling - tim clean
Iso Alcohol. Or better still the neat stuff. I would NOT use Meths. That will leave a residue that may interfere with the thermal paste.
Iso Al evaporates once you've cleaned the surface off.
Make sure you get none of the old paste on the pins whatever you do!
Chemists often have it, but if you can find a hifi store they may have a bottle of it by Allsop etc for cleaning purposes.Where can i get ISO Alcohol ?
It is.Is ISO-PROPYL ALCOHOL the same as ISO Alcohol ?
if used meths and then cleaned the surface with a tiny drop of fairy liquid would that be ok as fairy liquid gets rid of grease etc on dishes.
Is surgical Spirit the same as ISO Alcohol ?
God all this effort just clean a tiny CPU surface .............
Yes. The purpose of it is to ensure better heat conduction by filling the tiny gaps between the CPU and its cooler. Some CPU coolers come with a ready applied thermal pad. If applying paste a blob about the size of a couple of grains of rice is sufficient, spread into a thin even layer over the centre of the CPU using a credit card or similar
