Getting really annoyed with SonicStage
Discussion in 'Headphones, Earphones & Portable Music' started by caz1979, Mar 13, 2005.
  1. caz1979
    caz1979
    Feb 23, 2005
    61
    Ok folks I have managed to totally mess up SonicStage. I was running version 2.3 with no problems when I decided to upgrade to version 3. When I tried to log into Connect it gave off that I was connecting from outside the US. Given this fact I decided to uninstall 3 and put a clean install of 2.3 on my laptop. Ended up having to format the HD3 and initialized the player but I can't transfer music purchased from Connect as it says my player isn't authorized. I am still able to transfer all my other music files.
    When I click properties I can see a section saying the player isn't authorized so I click the button that says 'Authorize'. Here I'm taken to the Connect website. I can log in with my details but I still can't transfer my purchased tracks. I tried putting version 3 back on and have now reverted back to 2.3. I can't find out how to authorize the player as I'm already registered with Connect and the player was registered with Sony.
    Someone please help me as some of my favourite tracks won't transfer.
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    Sounds a bit annoying!
    I really don't know what is up with that, I would suggest emailing Sony detailing your problem. They are usually pretty speedy in giving a reply.
    Sorry I can't help!
  3. Hasselhoffia
    Hasselhoffia
    Well on the Connect Music Store on the Your Account page it should be showing something like:
    'You currently have 1 computer and 1 device authorized to play your purchased music.'
    I had a nice surprise just a moment ago, got an email from Sony Connect with a voucher code for 45 x $0.99 downloads from the site, simply for having registered my device with the US Connect Music Store. I'm from the UK. :)
  4. washout
    washout
    yepi can vouch for that, i got the 45 bucks worth too, im in ireland. yes it should say u have x pc registered and x devices(i have 2 hd1s on 2 machines and can swap connect music between them)
    if its the same in the uk why are people having trouble registering their units?maybe some good can come of his murder.
