Getting NTL sound through speakers
Discussion in 'Cable TV & Virgin Media TV' started by GBaino, Feb 21, 2003.
  1. GBaino
    GBaino
    Can anyone help with the following
    Im trying to get the NTL Digital sound through my AE Aego P5 decoder so I can listen to it on the Front and Centre speakers.
    As the Pace STB D4000i has no phono outputs, I have run the sound through my Video (SCART to SCART then Phono) and works fine (but takes up too much space) Want to run SCART to 2xPhono from STB to Decoder instead. Will this work? I has a old SCART to 2xphono but it was labelled Audio and Video output, and didnt work. Is it as simple as buying a new one with audio phono only or am I stuck with the Video?
  2. jmack
    jmack
    i have a aego 5 system and ntl but mine has audio out, but it should be easy to get a good scart with audio out , get it from maplins you can always return it
  3. GBaino
    GBaino
    Cheers, Ill try that.
