Getting New Sony Amp
Discussion in 'AV Receivers & Amplifiers' started by MURFER, Feb 13, 2003.
Tags:
  1. MURFER
    MURFER
    I am looking at getting the Sony HTK-25 HC kit. The tv I have Is a Philips 32 Flatscreen with built In DVD player (32pw6826). Will I be able to watch dvd's In DPL2 & DTS as the amp has this but I dont know If the built In DVD does?
    Also will I be able to watch my SKy in DPL2.
    Thanks In advance, I hope Im not being too stupid.
    Murfer
  2. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    Sorry do not know that TV but...
    Prologic 2 can be applied to 2channels, so as long as the TV or Sky STB has a phono or SCART output you're fine.
    For DTS or Dolby digital you'll need a digital output.
    spence
  3. MURFER
    MURFER
    Digital output?
    Would this be on the back of the TV?
  4. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    If the DVD is integrated then yes a digital output would be somewhere on the TV, they come in two basic versions, electrical or optical.
    The other possibility that slipped my mind was that the TV/DVD player might do it's own DTS/DD decoding and have a 5.1/6.1 phono output, which you could take to your amps 5.1 input.
    spence
