getting my PS2 on line
Discussion in 'Playstation Forums' started by newstuart, Oct 2, 2004.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    hi guys im just in the middle of wiring my home cinema and want to take the time for a little forward planing as i want to get my PS2 on line sometime soon.
    The PS2 is in HC room but modem and pc in another,at the moment I have floorboards up to run cables between the two rooms. What cables to I need to run for the PS2 to enable me to get it up and runing in the future ?
  2. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    ps2 broadband patch cable
  3. nero0410
    nero0410
    Jan 5, 2004
    12,096
    Weston Super Mare, UK
    +4,640
    after buying the network adapter, you will need a longer version of the cable that comes with that which is a patch cable as in the previous post or even a crossover cable works nicely i find.
    I have the voyager 200 router from bt which works a treat.
    Hope this helps to some degree
    tris
  4. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Thanks for the responses however I wont be buying everything just yet as funds a little low just need to know what extension lead i will need to run about 8 meters from the modem to the adapter i will buy for the ps2 at a later date please ?
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    a normal network patch cable
  6. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Why use these long leads etc?? Just get a wireless router/modem some access points and voala, no cables!
    S
  7. Stinja
    Stinja
    Aug 13, 2003
    12,486
    163
    +3,953
    Future proof for cabling?
    Cat6 cable now. Then just add a couple of drawlines to pull anything you may need in the future through later (fibreoptic, NinjaStealth4000 DVI Godzilla-raper etc).
