getting ir to cabinet
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by sirata, Jul 22, 2003.
  1. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    I`m looking to build a ht with a dedicated small room at the rear
    housing all the equipment.
    I`ll probably get a pronto,my question is the equipment room will be about 16ft from the screen,whats the best way to get the signal in there,i had a powermid in the house,but found some days it would work/some days not.
    Iwas hoping to have a sensor below the screen and a cable running behind the walls to an emitter in the equip rack, is there
    such a hard wired thing,or has any body got a good solution.
    The thing i found with the powermid,if someone knocked it, it
    would need moving before it worked again, i want something thats hidden and works everytime.
    Thanks for any help
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Xantech make the best stuff... Try letsautomate.com
  3. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Niles IR extenders will do the job.
  4. BigAde
    BigAde
    Jul 22, 2002
    1,025
    East Sussex
    +30
    Try the Keene remote extender - approx £50 from:
    www.keene.co.uk
    Works well for me anyway.
  5. noop
    noop
    i found the keene kit to be functional however i couldnt get the ir receiver to pick up a signal over 3 metres .... I changed batteries in my remotes changed the receiver position several times, made sure there wasnt any other interferance with no better results. I contacted keene and whilst helpful I was informed that the receivers were designed that way and wouldnt pick up any further than the distnace mentioned ....
    My room isnt huge (25ft x 14ft). I ended up using the multi ir receiver that is on letsautomate .... A little more expensive than the keene offering but it is a better design (smaller with less cabling) and has a much more powerful receiver ....
    All my kit is housed in a bespoke piece of furniture behind solid doors and this ir system is excellent ....
  6. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Hi noop, I'm getting a similar range problem with Powermids ...
    Which multi IR receiver on letsautomate did you mean? Have you got a web link?
  7. alistair
    alistair
    I have a pronto 9500 with RF. This works very well and is wire free (except for the cabinet that it). Have been pleased with it so far. Can switch between rf/ir so lights work just as well. Those colour graphics are pretty cool too. Talks X10 too if you need it.
    Not sure on your budget but if like the pronto product ( I admit not everyone gets on with ccfs) then go for it.
  8. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    Noop,
    I am interested to read about your experiences with the Keene IR extender. I am using the same setup in my HC to control all of the equipment in a cupboard and also my Tivo in the lounge. I have found it to be ok until last week when I started to experiment with using a Dell Axim PDA as a colour remote. I have found that it is a bit more directional (that might read, less powerful) than the black and white pronto I have been using.
    Reading your post it occurs to me that It may be worthwhile fitting a xantech receiver to my existing system to see if it improves the effectiveness of the PDA based remote. My couch is about 2.5 meteres from the receiver which is sitting on top of my centre speaker.
    I would ideally like to just add the xantech receiver to the keene system as my wiring from receiver to cupboard is in the wall. Do you think this will be possible as I note that the keene system is 12v DC and letsautomate state that the xantech receivers are 9v DC. Strange as Xantech's website state that the 480 dinkylink receiver is 12v DC.
    If I have to use a xantech connecting box and power supply do you think I will get away with using the keene emmiters as the one going to my lounge is not going to be easy to replace. The one in my cupboard is a high power blaster which controls the DVD and amp.
    Sorry for the long post. Your thoughts would be appreciated.
    cheers,
  9. sirata
    sirata
    Jun 14, 2003
    296
    28
    GUERNSEY
    +53
    Thanks for the info guys
    These forums are so useful,how did we manage without the net
    Dave:: :)
  10. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    Noop,
    Thanks for putting the idea of using the Xantech receiver into my head. To be honest I never thought of trying it to see if it was any better than the Keene setup. I got the Xantech stuff through letsautomate yesterday and bingo. I can now point my Dell Axim pretty much anywhere in the room and it picks up the signal. It has made my Axim much more functional and reliable. I was beginning to think about buting a pronto pro to see if it was any better.
    but not now!!
    cheers,
  11. wb1
    wb1
    Sep 5, 2003
    1,671
    38
    London
    +21
    Gavin, so you've plugged the Xantech receiver into the Keene IR distribution box? did you have to modify anything or was it plug and play?
    Thanks,
    William
  12. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    william,
    No I bought an entirely new xantech system from letsautomate.com.
    works a treat and i sold on the keene system to another forum member.
  13. wb1
    wb1
    Sep 5, 2003
    1,671
    38
    London
    +21
    Thanks Gavin - which Xantech did you get?
  14. GavinBrowne
    GavinBrowne
    Jul 23, 2001
    237
    Edinburgh
    +4
    William,
    Here is a copy of the order I placed with letsautomate.com
    Part No: 10889
    Description: Xantech CB20 One Zone Connecting Block (
    Unit Price: GBP 18.80
    Part No: 10065
    Description: Xantech 291 "Hidden Link" IR Receiver (I
    Unit Price: GBP 58.64
    Part No: 10885
    Description: 9V AC adaptor for use with Xantech equip
    Unit Price: GBP 9.40
    Delivery Method: Registered Post @ GBP 5.50
    Order Total: GBP 92.34
