getting halo to boot from harddrive instead of cd
Discussion in 'PC Gaming & Rigs' started by rooney, Sep 1, 2004.
  1. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    bought halo for my pc week ago its driving me mad keep inserting the cd
    cd in cd out cd in cd out and on and on
    ii have tried to copy it on to my hard drive when i boot it from there it still asks for cd any ideas so i dont have to keep using the cd
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    try using daemon tools, its free i think and itll let you rip the cd onto your harddrive then mount the images onto the program and play that way
    do a search in google
  3. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Sounds like all you need is a 'no-cd' exe from gamecopyworld.com - simply replaces the original halo.exe file and will launch the game without the need for the original cd in the drive.
  4. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    thanks for the quick response guys but they dont apear to work
    i have version 1.04.067 serached the net last night for no cd for this version no joy the daemon prog wont pick it up any more ideas guys ta :clap:
  5. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Rooney - sorry to have to say this, but did you even bother to look for the no-cd file from gamecopyworld.com as I suggested in my earlier post? I just checked myself and there is a v1.04 fixed exe for download.
    If you have indeed downloaded the fixed exe and tried it to no avail, then fair enough - but if you haven't then I suggest you do so before asking for yet more help having not even bothered trying... :confused:
  6. rigman
    rigman
    Dec 14, 2000
    2,897
    83
    East Yorkshire
    +87
    Do you end up with spyware / viruses all over your system by installing stuff like this. I tried to get XP SP1 to load on my machine and had to use a crack which ended up installing all sorts of crap.
    Darren
  7. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    No, I can honestly say that I've never had a problem with anything that I've used from gamecopyworld.com. I'm not a hardcore gamer, but I've downloaded no-cd exe files for all games that I've installed on my PC.
    In this case, the Halo 1.04 fixed exe is simply one file once uncompressed; a new halo.exe to replace the original one - the only difference being that the fixed exe doesn't require the cd to run the game.
  8. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    the exe file does not work a dos screen loads up then nothing thanks anyway guys
  9. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    {Link deleted, sorry not allowed to post links to sites which promote piracy}. download the 1.04 no cd crack. then if you have winrar click on the file then extract it to the halo file on your harddrive. it will come up do you want to replace the old file with this one. just say yes then the game will work without a cd. hope it helps :clap:
