Getting games onto the xbox harddrive
Discussion in 'Xbox Forums' started by H4r7y, Oct 1, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    ive tried to put my games on the hard drive.
    i manage to get one in the small partition perfectly, i can then play it from the dashboard.
    but, i go and put another game on, in a different partition. F: i think.
    but these games dont seem to load or even be seen by evoX!
    if i load up avalaunch then it will see them on the hard drive but wont load them up.
    is this a problem with the dashboard? (needs updating maybe?)
    or do i have to have a play around with the evox.ini file?
  2. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    Are you using the HD loader software ? If so I dont see what the problem could be. I have an uprated 120 gig hd in mine with around 20 games on it. Never had any problems.
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    ive been using dvd2xbox.
    not used hd loader
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I cant comment then. I just took mine down to a computer fair, they chipped it put the bigger HD in with all the software pre installed (XB media player, region free DVD, HD loader etc etc etc)
    The HD loader software does what it says on the tin. Just put the disk in and it makes a 1 - 1 copy on the xbox HD. The only time I have had to mess with the config files was setting up ftp and connecting the xbox to the network to stream audio ./ video files.
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    i take it that your talking about xhdd loader?
    or is it just called HD loader?
  6. harrisuk
    harrisuk
    Jan 24, 2003
    5,322
    71
    +58
    I will have a look next time I boot it up and let you know. I thought it was just called HD loader.
  7. inzaman
    inzaman
    Dec 16, 2002
    7,885
    Derby
    +935
    I just do the same as harrisuk, load a game to hd and its there. The software i use is projectx hdd loader.
  8. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    ive just had a play with the evox.ini file and it works like a dream now.
    the program was looking for it in another folder.
    thanks for the replies guys.
