Getting flicker on projector images from DVD playback
Discussion in 'Desktop & Laptop Computers Forum' started by dan1979, Oct 23, 2004.
  1. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    PC hooked up to my Panasonic AE500, I run dvd's at 1280x720 native resolution using PowerDVD.
    Most of the time it looks fine however when the camera pans slowly there is a lot of flicker.
    I assume its something to do with refresh rate, most of the DVD's I'm watching are PAL so 50Hz and I think standard monitor refresh rate is 60Hz?
    I tried changing the refresh rate in Powerstrip but I kept going out of the projectors range and sending the screen blank.
    Does anyone have a similar setup who could shed some light on what settings I should use to eliminate this problem.
  2. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Are you running through vga or dvi, what graphic card are you using and what dvd software are you using. I have an ae500 and dont get any flickering on pans. When you say flickering do you mean juddering or jerkiness.
  3. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    I'm using DVI, graphics card is a XFX Ti4200 sofrware is PowerDVD
    Its definitely a flicker I'm getting, its only on slow pans, just a sort of flicker along the middle of the screen as if its not quite keeping up with itself.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Is this tearing? A Ti4200 isn't sluggish I'd have thought. While playing PAL at 60hz can cause a stuttering, I'd not have thought your description was of that. In any case, my projector only accepts 60hz too and I don't see this sort of effect.
    What does playback look like on your monitor? What about VGA?
  5. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    Never noticed any problems with VGA though I haven't watched many DVD's through that.
    It's not down to a weak graphics card, I've watched stacks of the windows high def demos on here and they work perfectly.
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    If its tearing (which it sounds like it is) it could be a video to audio sync issue. I couldn't get PowerDVD to work properly at 50Hz.
    Reclock has a very useful utility to show if the audio\video sync is an issue. I think its a tickbox at the bottom that shows vsync tearing. It will scroll a bar horizontally across the screen to show you if sync is an issue. You can then adjust your powerstrip settings accordingly to set this right.
    I dont think reclock works with PowerDVD though.
    Try a different software player to see if the issue persists.
