Getting digital sound from PC
Discussion in 'Computer Components' started by Alexg, May 26, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Guys,
    I've got a sound blaster platinum 5.1 (about 3 years old) I've tried everything I can think of to get the digital output from it working with my amp (Sony STR-DB940) I just cannot get any digital sound working from it at all be it SPDIF on the front bay, optical on the front bay and the digital 3.5mm jack on the actual card. All the drivers are installed and the creative software.
    Help!
    Thanks, Alex.
  2. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Really need an answer on this guys, tried searching to no avail.
    -Alex.
  3. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    you have enabled the spdif output in the soundcard driver and the spdif output in the player you are using?. Mike
  4. martian1
    martian1
    Dec 30, 2001
    2,394
    113
    Sunderland
    +638
    Well let me know this and i may help..What dvd software do you plan to use ie powerdvd Theatretek.
    You may need a sound filter like AC3 for passthrough has your card got spdif out connection?
  5. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    Have you gone into the advanced sound settings in windows and enabled spdif pass through. I had this problem and by doing this it solved it for me.
  6. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Ok, where is "spdif pass through" ? can't find that option, I've found "digital output only" but ticking that doesn't make much difference.
    I've got an AC3 codec, and nearly every other codec under the sun installed.
    I've tried power dvd, win dvd, media player etc.
  7. Rambles
    Rambles
    Jul 14, 2004
    8,093
    UK
    +1,067
    So you have a cable from digital audio out on the sound card to digital audio in on the amp, and you have the amp selected to the appropriate input.
    In the sound card drivers panel look for and enable everything that is connected to spdif passthru, or digital audio out, or multi channel via amp/receiver.
    Go to control panel, sounds and audio devices, advanced and make sure that spdif is not muted (tick in the mute box should be removed).
    Restart your computer, turn the volume of the amp up, see if you get any windows sounds. If so then you just need to configure your media players and audio codecs correctly to enable the spdif passthru.
    Let us know if it works
  8. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Thanks Lisa,
    I can't find anything that referes to "spdif pass through"
  9. Rambles
    Rambles
    Jul 14, 2004
    8,093
    UK
    +1,067
    The main ones to find are on the sound card drivers and check that spdif is not muted in windows. From Control Panel - Sounds and Audio devices - Advanced - Options - Properties - Make sure SPDIF is ticked in 'show the following volume controls' - then check that it is not muted.
    What do your sound card drivers look like? What are your options, can you post a screen grab?
    Thought of something else - does your motherboard have onboard sound? If so have you disabled it in the BIOS.
  10. Dazb75
    Dazb75
    Jan 20, 2005
    76
    Bangor NI
    +4
    The AC3Filter (if that's what AC3 codec you are using) has a configuration program. Usually it is setup to handle all digital output (AC3, DTS, etc) and I think the default setting is 2-channel output.
    Anyway, all creative 5.1 cards are notoriously bad for outputing 5.1 sound to an amp. The digital out on the card is only designed for creative speakers, which isn't made very clear when you buy the damn thing!
    Search around. There are other sound-card related forums in which this subject and some good tips are discussed at length.
