Getting Confused - please help
Discussion in 'Plasma TVs' started by how1970ard, Jan 14, 2005.
  1. how1970ard
    how1970ard
    I am trying to improve the picture i have from my sky box to my LG plasma screen.
    I only have RGB/S-video/RCA connections on the screen.
    There are numerous other connections but seem to be geered towards using a pc with the screen.
    Please help as the sky pic is very disappointing.
    Howard
  2. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    RGB scart to scart should provide a reasonable picture....................it may not be the connections..........but the plasma................how does it look with DVD?
    RGB - VGA converter will give a slight improvement to Sky.
    Cheers, Tam
  3. freeman
    freeman
    Dec 27, 2004
    240
    +11
    It gave a major improvement to mine :clap:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    RGB>VGA wont work with LG IIRC ut check JS technology site... RGB>YUV will work.. best way to improve PQ is to add a scaler but £800 ish is expensive.......
