Getting a Viera 42PE30B on Tuesday and I have a question...
Discussion in 'Plasma TVs Forum' started by thredworm, Sep 12, 2004.
  1. thredworm
    thredworm
    I've looked all over these forums and I can't seem to find a definite answer. I know the Viera will not play anything at 720p, but will it play at 1080i?
    If I have a hd-dvd at 1080i am I likely to see a difference on the Viera to that of a normal dvd?
    Thanks for any help. :)
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    When I first read the posts here I got the impression that the Viera couldn't display 720p or 1080i but on reading subsequent posts I think that it can downscale 1080i signals, I'm not entirely 100% on that. It does seem that the Viera can't do anything with 720p though.
    If 1080i signals do work would you see a difference from normal interlaced or progressive PAL signals? I wouldn't know, sorry, I've not been much help.
    S.
  3. thredworm
    thredworm
    Anyone able to answer this?
    Thanks.
