Get Sky+ to Epson EMP TW10H?
Discussion in 'Projectors, Screens & Video Processors' started by DigiTALGuy, Sep 9, 2005.
  1. DigiTALGuy
    DigiTALGuy
    I'm thinking of making the move to the Epson TW10 and was wondering what the best method would be hook up Sky+ to the projector?
    Can I feed it direct into the projector? If so what cables would I need.
    Or would I be best to take it through a secondary device such as a DVD player?
    The specs for the projector are here:
    http://www.epson.co.uk/products/video_projectors/product_spec/EMP-TW10H.htm
  2. Lucas
    Lucas
    Jun 29, 2005
    103
    +3
    The epson comes with a Scart adapter so you could connect it to the RGB output of Sky+.
    The signal would still be interlaced though. The epson doesn't have top notch deinterlacing circuitry. It works best with a progressive signal. This means that your picture with a progressive scan DVD player would be better.
    You could try it though and see what the results are like.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    579
    Scotland
    +17
    I'm currently using the same projector with SKY +
    I have it connected to the Component Inputs (sync on composite?) using the supplied scart adaptor. The resulting picture is actually very good.
    You could also connect your SKY + box to the projector using S-Video.
    Again, this gives very pleasing results.
    I view the projector from around 12ft away, with the picture projected straight onto a white wall.
  4. Hilly131
    Hilly131
    What about a standard telewest box to the Epson tw10h? How would I go about it connecting it that way?
    I am a student and could only afford the basic package - it's for the champs league mainly.. Watch The mighty Reds win it for the 6th time!!
  5. andylorenz
    andylorenz
    Mar 12, 2005
    98
    +10
    hi hilly131 - suggest you look at my post here regarding Telewest to TW10H:
    http://www.avforums.com/forums/showthread.php?p=2344144#post2344144
    hth, the thing that really caught me out was the composite sync ...
    cheers
    ps - just noticed YOU posted that thread in the first place, so I'm wondering why I bothered to post all the info for you if you just ignored it ... oh well, maybe will help someone else.
  6. Hilly131
    Hilly131
    sorry AndyLorenz I think I posted on 2 message boards hoping to get a quick response at the time.. I have taken on board and what you have said from the other thread.. was a great help and I am sorting finances to aquire the correct equipment.. cheers mate
