Get Sky+ remote to control your AMP
Discussion in 'Home Cinema Buying & Building' started by Ianc, May 23, 2004.
  1. Ianc
    Ianc
    I thought this was impossible .... but Ive just tried these instructions and bingo my new panny amp is working from my Sky+ remote...
    This is great! , long list of makes & mfrs' amps etc for you to try.
    Im posting this because I searched long & hard and hte only threads I found said it was not possible - then I stumbled across this...
    http://www.hummer.co.uk/remote-setup.htm
    Usual caveats apply - if you kill your remote... it was you who killed it but I can confirm mine works fine!.(panasonic scdt)
  2. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Thanks! will try it tonight and let you know if it works!
    Rob
  3. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Great! :clap:
    it worked fine for me, even got it to control the Volume too!
    Cheers for that! Rob :smoke:
  4. tall.small
    tall.small
    Oct 4, 2002
    94
    Kings Lynn, Norfolk
    Does this work with an ordinary Sky remote not just Sky+?
