German voltage issues?
Wolfman310
I was just thinking about importing some electrical items from germany, like you can with the Canton speakers, but......
Would the menus and display be able to change to English, as i understand they would be in German?
Also, what about voltage, would you be able to just cut the plug on that and put a UK plug on the end? whats involved?
Thanks for the advise!
pragmatic
I would think that most the units would be for the whole of europe and as such most things will be in english.
S
SKA.face
All europe runs 220 volts,so just change the plugs.Whenever you buy something these days,it comes in quite a few languages,so I see no problem there either.
DRGL
Not 100% sure whatb plugs europe use but you can get converter plugs so you don't have to chop the fitted plug off :) They look just like a normal mains plug-all my Sony equipment has them as standard!!!
Reiner
Germany uses 230/240V and 50Hz, so that's no problem. The German plug is either the "Euro" type (flat with 2 round prongs, no earth) or "Schuko" (round shaped with 2 round prongs and earth). Replacing it with a UK one should be no problem.
If menus are available in English, too, would depend on the manufacturer (I tend to say 'yes' but you never know unless you check).
Duster
Yes, That will be fine.
I'm an English guy living in Germany at the moment, So I know for a fact that Stuff that I've bought from Germany works in England and stuff I've bought from England works in Germany, all that is needed is a plug change.
machinehead1
my 2500 imported from www.tsn had a ext three pin plug inside the box,so there was no need to cut any wires.i'm also sure that maplins would sell these plugs for a couple of quid.would save cutting anything if you had a fixed mains on anything electrical.
regards machinehead
Wolfman310
regards machinehead
Hi, the link doesn't work, any ideas?
Wolfman310
Duster said:
DO you think it is worth importing from Germany, or would you not bother?
Duster
Somethings are really cheap, like petrol and food, and somethings aren't.
I don't think you save that much really on hi-fi from buying in Germany, and if you have a problem, then you have the extra problem of shipping it back.
I saved £100 on a Arcam AVR 300, by buying it in Germany.
Like others have said, you can find a good deal over here, but then , if you look around back home to, you can find good deals.
I only buy from Germany because i'm over here, as soon as I return to the UK, then I'll be buying again from the UK .
pragmatic
The Yamaha warranty is pan-european and Yamaha stuff seems to be cheaper in Germany. Denon and marantz on the other hand appear to be more expensive especialy after you consider the extra costs of currency tranferal and delivery (which is supprisingly cheap)
Wolfman310
I have noticed some manufacturers are more expensive in germany whren you total up currency and postage, but some are a lot cheaper, a tadge weird i think.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
