Geometry Question + slight ghost lines
Discussion in 'Televisions' started by nfshirley, Oct 30, 2004.
  1. nfshirley
    nfshirley
    Sep 23, 2004
    15
    I have recently purchased a Sony KV32CS70, which on the whole I am very happy with, but I have two questions. With SKY+ connected via SCART and set to RGB I had to adjust the geometry to +2. After one month of use I have had to set this to +3 and it may have to go to +4. The setting only goes to +5. Will the geometry keep moving and what happens if it goes past the +5 setting to correct it? Am I stuck with a sloped TV picture?
    On another note, there is a ghost image about 20mm either side of the TV that you can just about see (it is extremely faint but I notice it - the wife doesn't) - does anyone know what this is?
