Geometry on Philips 32PW6542 widescreen
Discussion in 'Televisions' started by booker, Mar 16, 2005.
  1. booker
    booker
    Mar 16, 2005
    77
    9
    I still can´t get it right...
    I have this new tv and i´m on the service menu, trying to get the best ratio as posible.
    My goal is to get the WS and 4:3 ratio the best i can. Actually my problem is that some edges are curve, so they deform the picture.
    Does anyone accomplish this?
    any tips or advice?
    Also, it is posible to set 1 setting for NTSC and 1 for PAL?.. no matter how i do, my PAL settings don´t show the same as NTSC, so when i watch a picture on PAL it looks like i calibrated, but when i do it on NTSC it don´t... and the same thing if i tweak NTSC, it won´t look good on PAL
  2. Murrhay
    Murrhay
    I have same TV Set with exactly same problem. I think the origin of the problem was an EMI radiation from the power outlet, but not sure. This could be solved using a degaussing techniques, but it is too risky if you don´t know how to do it.
    I would like to start looking in the service menu, do you know how to access? Can you please explain to me?
    Thank you.
    Sergio.
