kingsize
Established Member
Just purchased both.
The auto setup on the amp rigs all the genies as 'small' which I assume is correct.
It has auto set the crossover at 160.
Is this correct, or can anyone say what the crossover should be?
It's all a bit befuddling to me...
Any help would be much appreciated.
Also do I have to set the amp up to deal with the geines @ 4ohms? The manual suggests that you should set it up for speakers at 4 or 6 ohms, but the genies are rated 4-8 ohms....very confused...
Thanks again.
Thanks again.
