genie sub auto cutout?
Discussion in 'Home Cinema Speakers' started by andre 3000, Nov 3, 2004.
  1. andre 3000
    andre 3000
    why does the genie sub cut out in quite scenes,especially when watching digital telly at lowish volume?. apart from that it's the nuts :hiya:
  2. bbasra
    bbasra
    Sep 15, 2004
    1,660
    48
    Hounslow
    +42
    hope it's not faulty or it may be some sort of powersaving?
    Any suggestions?
  3. Beobloke
    Beobloke
    Aug 10, 2004
    1,314
    Out in the Sticks!
    +66
    Do you leave the off/auto/on switch in auto? If so, try switching it to on and seeing what happens. it sounds like the auto on/off circuit could be a little under-sensitive!
    Adam.
  4. nicklang
    nicklang
    Jul 6, 2004
    190
    Newport, South Wales
    I had a MS-906w subwoofer and it used to power off in the quiet parts, it used to make a popping sound when it did it. I sent it to MS and they replaced it, however the replacement did the same, so I sold it.
    It could have been the marantz sr6200 I was using? could it be the amp?
    Is yours popping when it powers off?
