Genie centre speaker - direction?
Discussion in 'Home Cinema Speakers' started by veedubba, Mar 11, 2006.
  1. veedubba
    veedubba
    Mar 3, 2006
    40
    Just setting Genies up and centre speaker is angled up too much for my taste, can I point it forward instead of up at 45 degrees. Sounds like an imbecile question but heard the tales of undoing alen screw too much, the stand will twist freely but no up and down movement.
  2. M4CCA
    M4CCA
    Dec 7, 2005
    132
    All Genies are easily adjusted as long as you follow 1 rule:-
    when adjusting make sure you hold the stand in position and not the speaker itself otherwise you will overtighten/move the speaker during adjustment.:smashin:
  3. veedubba
    veedubba
    Mar 3, 2006
    40
    Thanks M4CCA
    Ican get the speaker to move side to side easily but not up and down, the allen screw only want to move very slightly too.
    Steve
  4. M4CCA
    M4CCA
    Dec 7, 2005
    132
    You should get a good degree of movement up and down as well, try slackening it off very slightly then trying to move the speaker whilst supporting the stand.
    You will find it easier to move the speaker up and down if you place it on the stand on a flat surface and whilst holding the stand down tightly with one hand move the speaker with the other.;)
